MyTheatre Scanning Sat hangs?
Old 31-05-2003   #1
Question MyTheatre Scanning Sat hangs?
Trying to run up MyTheatre, which looks like a very nice program. Its ver 2.75 typical install on win2000 with TwinHan
card TV@Sat.
When I attempt a scan on a valid tp goes "0 found so far" time keeps incrementing on and on with no result. Trying stop, goes "waiting finish current transponder", cannot close box (need to use Task Manager to close app).
If I run alt program winDVB ver1.1 (came with card), this works ok,
seeming to prove card/pc/dish setup ok.
MyTheatre identified hardware as TwinHan when I installed it, when I tried other Sky settings, the scan dialogue then instantly dispatches ie not found, and going back to check TwinHan then restores the hanging behaviour.
On LNB menu, I did apply Ku-L for my universal LNB OK.
Have reinstalled MyTheatre, same result.
Hopefully you can throw further light on this, have I missed something?
Thanks.
Pedro
pedro is offline   Reply With Quote
Old 01-06-2003   #2
rolfw's Avatar
Real name: Rolf
Can't say that it's a problem I recognise Pedro, have you tried it with ProgDVB? Unfortunately I don't know anyone else with the twinhan card, but believe that it shouldn't behave any differently from the Skystar.
Rolf
Old 02-06-2003   #3
Hope this helps,
Select the sat u want then click on KU-L then apply, then on the right hand side sel all then scan when scan is complete use the esc key to exit back to my threatre
stan01 is offline   Reply With Quote
Old 07-06-2003   #4
Update
Thanks for the replies, Rolfw and Stan01..
I'll try it with ProgDVB?
Have since tried the existing hardware with "DvbTn" and this works.
Stan01.."when scan is complete "...this doesn't happen for me..
Because the program does not find anything, I'm thinking may be the problem relates to the lack of response with the twinhan card ie driver issue? Maybe I should try an earlier (simpler) ver. of MyTheatre?
Any thoughts...
cheers
Old 09-06-2003   #5
Pedro try this website u might find the answers there
http://forums.dvbnetwork.com
good look m8, stan
Old 14-06-2003   #6
Update (2)
Latest ver 2.7 works nicely!
("Fix scan lockup with twinhan cards ").
cheers
pedro
hangs, mytheatre, sat, scanning
Similar Threads
multiswitches spiney Tutorials & How To guides 10 24-02-2007 05:43 PM
Shuttle +VisionPlus sat CI + myTheatre salem6 Satellite PC Card Receivers & Internet by Satellite 2 22-09-2004 07:54 AM
Mega Cosmos on Hellas Sat 2 net1 Daily Satellite and Broadcast industry News 0 22-02-2004 05:49 PM
!!Help!! Need a sat signal finder. (Loaned or Hired) in UK jAk DISH SETUP: Single sat, Multi-Sat & Motorised systems 1 25-01-2004 06:59 PM
