Skystar2 pci and nforce4 chipset- Warning!
Old 17-12-2005   #1
My System: Skystar2, Fortecstar Passion HD, moteck 2100, Lidl 80cm dish
Having discovered that I can't use my Skystar2 pci in my new motherboard (Asus A8N SLi), I thought it worthwhile starting a new thread to highlight the issue, which has resulted in some people damaging their motherboards.
See this link:-
_http://www.dvbviewer.com/forum/index.php?showtopic=7761&st=0&p=63636&
I would also like some advice on what to do now, as I need a Skystar2 compatible Socket 939 motherboard, which will accept my AMD64 4000 cpu and my nvidia 7800gt pci/e graphics card.
Any suggestions as to what would be best?
Woody
woodlouse is offline   Reply With Quote
Old 27-12-2005   #2
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
yes, it's something to do with a lack of voltage on the pci bus on that mobo
i have a msi neo4 platinum nforce4 ultra running sweet with ss2
you might also want to check out the new geforce 6150 onboard gpu µatx mobos
kamaleon is offline   Reply With Quote
Old 30-12-2005   #3
pinkerton's Avatar
I'm on my second Asus A8N MB which has now gone belly up, and I have read various reports of it not likeing TV cards in general. I have ordered a Skystar USB and probably have to RMA the second motherboard.
These things should come with a warning!
pinkerton is offline   Reply With Quote
Old 01-01-2006   #4
kamaleon's Avatar
i'm very very glad i didn't get one of those mobos...
i think there's a thread in dvbnetwork, otherwise should google for it. maybe abit, epox, dfi, gigabyte, msi all work fine with pci device like the ss2...
Old 06-01-2006   #5
FraserGJ's Avatar
My System: 35cm portable dish and Comag Porty II FTA Reciever (Lidl kit), Nokia 9850T DTT box. Athlon 2600+, 512Mb RAM PC with Nebula DTT Card
Oh dear, that doesn't sound good for me. Not good at all
FraserGJ is offline   Reply With Quote
Old 19-01-2006   #6
pinkerton's Avatar
Well I have RMA'd the Asus and am now the owner of a DFI lan Party Extreme. Someone stated on another forum that he was running the skystar2 on a DFI Nforce motherboard, only thing is I'm terrified to try it! I dont want to see a third board die on me, I think my retailer must think I buy them and throw them at the wall.
Old 21-01-2006   #7
Best of luck Pinkerton.
If you do decide to take the plunge, let us know if it works.
I just bought a Twinhan Starbox USB2 to use with my ASUS board.
Can't get the bl**dy thing to work though
Old 21-01-2006   #8
BGonaSTICK's Avatar
I read somewhere yersterday that a very high percentage of the Starboxes have been returned as faulty. Try a Google search.
Old 21-01-2006   #9
Got the Twinhan box working now, it came with a duff USB cable!
Seems to work fine with My theatre and plug-ins.
HDTV looks good on it as well
Couldn't get it work with Progdvb though, prog freezes when scanning for channels
Not yet worked out how to move the moteck from MT without USALS, is this possible?
Old 24-01-2006   #10
pinkerton's Avatar
OK, I went for it and I'm glad I did!
Skystar2 PCI working fine on a DFI Lan party Nforce4 Extreme. Even rebooted a couple of times and all seems well (touch wood). So all I can say is never use a Asus Nforce4 with a skystar2.
Skystar USB going on Ebay tommorrow as surplus to requirements.
Old 25-01-2006   #11
Pleased to hear it works.
Just for the record could you give the model number of your DFI board, if my Twinhan box goes belly up I might need to get one.
Also, are you using your SS2 to drive a motor?
Old 25-01-2006   #12
pinkerton's Avatar
I bought this board: _http://www.dfi.com.tw/Product/xx_product_spec_details_r_us.jsp?PRODUCT_ID=3872&C ATEGORY_TYPE=LP&SITE=US
I have a motor but not set it up yet, so watch this space
Old 26-01-2006   #13
D4ftpunk's Avatar
My System: Dreambox 7020 Dreambox DM500 Sky Thomsom Digibox StrongSat FTA Reciever 80cm Dish + 45cm Dish via Disecq A/B.
Im using a gigabyte K8NXP-9 motherboard which is nforce4 and my skystar2 works perfectly, the K8NXP-9 has a DPS card in it. which makes power nice simply heh.
Try it
give me money now
D4ftpunk is offline   Reply With Quote
Old 26-01-2006   #14
pinkerton's Avatar
Whats DPS?
chipset, nforce4, pci, skystar2, warning
Similar Threads
Warning another RIP OFF jayem The Meeting Place 2 18-02-2005 01:07 AM
Warning to ALL men... gameboy Wavey's Jokes Corner (May contain nuts) 5 14-01-2005 05:41 PM
What chipset is in my cam? damhy Cams and decoders General 0 11-09-2004 11:03 AM
WARNING - WARNING - WARNING ! w hole Announcements and News 3 11-12-2001 03:40 AM
