blind scanner for progdvb
Old 26-01-2006   #1
My System: channel master 1.2 technomate 5500 daci
is there a program that will run in progdvb to blind scan satellites i know there is one for the skystar 2 but i have a different and that program will not run with it is there any other ?????
nopms is offline   Reply With Quote
Old 26-01-2006   #2
My System: Various
If you have the old version of the Skystar 2 (v2.3), then set the symbol rate to 0 in ProgDVB and it will do a blindscan at the frequency entered.
Orthoclipse is offline   Reply With Quote
Old 26-01-2006   #3
i don`t have a skystar 2 as i said i have a hercules sat card
Old 26-01-2006   #4
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
You didn't mention 'hercules' in your first post.
The answer then is no, unless you edit each transponder frequency in the transponder file and repeat it with all possible symbol rates. Then save it and re scan. Be warned however that scan times will lengthen significantly.
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
blind, progdvb, scanner
Similar Threads
The difference between Blind Scan & Auto Scan al_madhi Digital systems 9 28-12-2005 07:13 PM
what is the best digital receiver for fast blind search for seeking out feeds sat200 DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 28-09-2005 03:18 PM
PID Scanner? Please help Benji Digital systems 7 16-02-2004 04:21 PM
satellite tv and the blind. stock The Meeting Place 0 16-08-2000 09:01 PM
