SkyStar 2 DVB PCI Card (newbie)Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Dream-Believer Join Date: 30-01-2006 Location: Guernsey Channel Islands
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w | | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hi there - to the board ![]() 1 Yes 2 Yes 28E 19E 13E and 30w is where most of the action is. Depending on your location in England, a minidish will give you a good taste of what's going on. As for channels - go to www.lyngsat.com and check the channels against those satellites. Also have a good read though the rest of this section and come back with any questions. L. | ||
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w | Thanks Lancelot, I have and old analogue system at the moment, will I be able to pick up different channels using the SkyStar 2 card?. Thanks | ||
| Specialist Contributor Join Date: 19-05-2004 Location: South East England
My System: Samsung A300W with component output Hotbird & Astra2 | Lancelot has already answered your questions. Please read it again. | ||
| Every little helps and a little help goes a long way! | |||
| | #5 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Thanks Jaffer ![]() Yes you certainly will THOUSANDS. Have a little read through. L. | ||
| | #7 | ||
| Regular Member Join Date: 22-12-2005 Location: Aberdeen, Scotland
My System: Motorised Triax 88 Dish, DP6600 VBox, Dreambox 7020S with 200gb hd, Linksys Router WRT54GS & Linksys Bridge WET54G. ADSL Internet. | Yep only digital with this card. Another question: As the skystar 2 doesnt have a cam slot like the ss1... is there a way to use cams that is compatible with progdvb or whatever the popular software is now? ...maybe a usb interface like the 'Duolabs Cas Interface Plus MK2' - £39 - Am I barking up the right tree? | ||
| | #8 | |||
Dishes only really come in two types, working or not. The signal is still only high frequency RF when the dish sees it, the reciever does the clever bit and strips the information from the signal. So his dish won't care ![]() There are 'add on units' available which can plug in to some PCI cards for use with a cam and sub card. L. | |||
| | #9 | ||
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w | Thanks guys, Could you give me a rough idea of what I will be able to receive with my analogue dish, will there be any english stuff like movies & music etc?. I am located in Guernsey Channel Islands. Thanks | ||
| | #10 | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | there is plenty of information on this site, please please have a good search and read b4 you ask | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
| | #11 | ||
| ucascity orphan Join Date: 03-07-2003 Location: cyprus
My System: amd3500+ msi 7800gtx 300gb hd creative 5.1 1gbkingstonddr400 motorised1.7dish twin0.3invecom lnb pace500ip echostar sr200ip nokia9600 metabox3 skystar2pci philips stb/digiturk | When you say analogue dish are you saying that you have the old type analogue lnb?if so you will need to change it to a universal type lnb to get the the higher frequency transponders. | ||
| | #12 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Yes! That's the point. Dish doesn't matter, but if the LNB is very old, it probably needs a nice shiny new 'universal' one. LNB's can deteriorate over time as well. With the cost of a new LNB so low, it would almost certainly be a good investment. STICK | ||
| card, dvb, newbie, pci, skystar |
Similar Threads | ||||
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| What Modem Pci Card do Netsystems use? | Mr G | Satellite PC Card Receivers & Internet by Satellite | 1 | 06-12-2003 01:47 AM |
| Which DVB card? | alnitak | Satellite PC Card Receivers & Internet by Satellite | 4 | 26-08-2003 02:17 PM |
| gizlog1.3 and twinhan pci card | radiotech | Satellite PC Card Receivers & Internet by Satellite | 1 | 18-08-2003 08:47 PM |
