CPU usage- DVB viewers?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 05-09-2005 Location: south scotland
My System: silvercrest receiver 80cm solid dish goldstar 0.3 LNB with satfinder motor Panasonic digibox Pace digibox goldstar 80cm mesh dish amstrad analogue receiver 1.5m antique solid dish/pond Skystar2 pc card 139 inline boosters! |
Hi, have had problems with freezing image on TPS foot/star & have upgraded from 733mhz CPU to 1ghz which has helped. Anyone know the best viewer for the least drain on the CPU? DVBdream is useful as it shows the usage. | ||
| Markyd23 don't touch the precious things..... | |||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | check progdvb homepage http://www.progdvb.com/ | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
My System: silvercrest receiver 80cm solid dish goldstar 0.3 LNB with satfinder motor Panasonic digibox Pace digibox goldstar 80cm mesh dish amstrad analogue receiver 1.5m antique solid dish/pond Skystar2 pc card 139 inline boosters! | Thanks, not sure what I was looking for though? my system is well above the basic requirements shown. | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | You could always use win98se instead of XP. That'd help a bit if you are suffering. L. | ||
| | #5 | ||
My System: silvercrest receiver 80cm solid dish goldstar 0.3 LNB with satfinder motor Panasonic digibox Pace digibox goldstar 80cm mesh dish amstrad analogue receiver 1.5m antique solid dish/pond Skystar2 pc card 139 inline boosters! | really? never thought of that. Is that because XP uses so much more CPU than 98? suppose I could connect a 2nd hard drive with 98 on it? | ||
| | #6 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Yes win98 is much easier on the CPU. But you will need to change the drivers accordingly. L. | ||
| | #7 | ||
My System: silvercrest receiver 80cm solid dish goldstar 0.3 LNB with satfinder motor Panasonic digibox Pace digibox goldstar 80cm mesh dish amstrad analogue receiver 1.5m antique solid dish/pond Skystar2 pc card 139 inline boosters! | Do you know if it's possible to get a cable so you can have 2 hard drives and the CDrom connected? | ||
| | #8 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Have a look in your PC, there should be spare capacity on the ribbon inside and a spare power connector in the chain anyway. If not you could always partition you HD. L. | ||
| | #9 | ||
My System: silvercrest receiver 80cm solid dish goldstar 0.3 LNB with satfinder motor Panasonic digibox Pace digibox goldstar 80cm mesh dish amstrad analogue receiver 1.5m antique solid dish/pond Skystar2 pc card 139 inline boosters! | Thanks for your help, will have a look. | ||
| | #10 | ||
Most mother boards these days have a primary IDE master and slave and a seconday IDE master and slave thus allowing 2 Hard drives and 2 cd Roms without a problem. Of course it may be that your mother board has the connector but no cable but the cable is not difficult to get hold of. | ||
| cpu, dvb, usage, viewers |
Similar Threads | ||||
| Digital satellite viewers lose free channels | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 5 | 16-06-2005 01:22 PM |
| Russian roulette TV stunt may have misled viewers | net1 | The Meeting Place | 1 | 11-10-2003 01:36 PM |
| We'll be back after this shorter break, UKTV tells viewers | net1 | Daily Satellite and Broadcast industry News | 0 | 28-08-2003 06:07 PM |
| Threshold comparison of DVB cards | deeno | Satellite PC Card Receivers & Internet by Satellite | 3 | 12-08-2003 06:20 PM |
| Solus Cards | zansi | Sky Digital (BSkyB) and Astra 28.2 East General | 1 | 06-08-2003 01:22 PM |
