HDTV with DVB-S PCI card?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Mad Scientist Join Date: 29-07-2005 Location: UK
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | Hello one & All. I think its possible to view HDTV on a PC using a DVB-S PCI card like a SkyStar 2 or a Hauppauge Nova-S with ProgDVB? Can someone confirm/deny? Also... anyone using Linux to view HDTV on a DVB-S card? See, in theory, as I recall, you can use a Dreambox to view HDTV if you use VLC on a PC. So as long as the PCI card will output the stream.. you should be able to do the same under Linux... but google is dry on examples! Anyone using a PCI card to watch HDTV? If so which one? Thanks for any help/abuse/off topic responses ![]() Paul. | ||
| ucascity orphan Join Date: 03-07-2003 Location: cyprus
My System: amd3500+ msi 7800gtx 300gb hd creative 5.1 1gbkingstonddr400 motorised1.7dish twin0.3invecom lnb pace500ip echostar sr200ip nokia9600 metabox3 skystar2pci philips stb/digiturk | I am viewing the 3 hdtv channels on 19 east with varying success,I use nvidia pure video decoder in conjunction with a ss2 card.The mpeg2 transmissions come in ok but mpeg4 one is a little choppy.All are hoggers of bandwidth,mpeg 2 averages about 12 to 14 Mbps but mpeg4 runs nearer 20Mbps.I will be changing my vga card to an nvidia 7800 or 7900 gtx 512(if available) next month to improve things.The standard for hdtv is to be set at something called S2 for future broadcasts,so for hdtv the ones we have now will be obsolete,new ones are due out soon. | ||
| | #3 | |||
Be interesting if there are some Mpeg 4 PCI cards that come along that support proper S2 and HDTV... | |||
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | Looks like Technotrend is the one to watch, with their new Technotrend S2-3200 HDTV-S2 due in March picccy here roll on CeBIT! Its even PCI-E which is good as I am out of PCI slots in my main PC | ||
| | #5 | ||
| Member Join Date: 20-04-2005
My System: turnkey 700mhz athelon .5gb ram,120 gb,drive j-test j-tag setup | North american HDTV is bdcast using '8psk' (dvb-s2) and mpeg-2. forthcoming trend is mpeg-4 witch would require a newer decoder,(hardware or software) with improuved features and a reduced datarate dvb-t here is mpeg-4 with excelent results. 'boxnut' | ||
| card, dvbs, hdtv, pci |
Similar Threads | ||||
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| What Modem Pci Card do Netsystems use? | Mr G | Satellite PC Card Receivers & Internet by Satellite | 1 | 06-12-2003 01:47 AM |
| gizlog1.3 and twinhan pci card | radiotech | Satellite PC Card Receivers & Internet by Satellite | 1 | 18-08-2003 08:47 PM |
