Recording From Ss2 To HddDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Specialist Contributor Join Date: 03-08-2004
Is there any special prog. or configuration that could shrink files of progs or movies being recorded from Sky Star2 to HDD? I find it difficult to record because the files are usually to big, several gigs for a two hour movie. I use ProgDVB. | ||
| Regular Member Join Date: 02-11-2004 Location: DUblin
| Hi Alan I dont think there is but I just bought a 250gb external drive for that purpose and it works fine through the USB2 connection. I found the only way to get the recordings shrunk and to fit on a normal 4gb DVD was to buy a programme called Magix edit pro10 for €28.00 from PCworld. Hopefully this is of some help Maurice | ||
| Regular Member Join Date: 15-07-2005 Location: Ireland
My System: Samsung Motorised COMAG sl55. Panosonic TUDSB 30 Sky box. | Hi Alan, You could also convert your files {after you have downloaded them] to AVI format about 700mbs for a 4.7 gbs movie. Try a goggle DVD to AVI. No noticable loss of quality. This is what I do when I want to keep something. John22. | ||
| | #5 | ||
| Member Join Date: 20-04-2005
My System: turnkey 700mhz athelon .5gb ram,120 gb,drive j-test j-tag setup | I use nero to burn dvds,if you use the 'recode' plugin, you can either check 'fit to trarget' ,recode as an 'svcd',(efectively what john22 is doing) or encode as mpeg4,(you need a player that supports mp4 to view these). a 2 hour movie fits well on 4gb disk with subtitles and dolby5.1 sound. cheers 'boxnut' | ||
| hdd, recording, ss2 |
Similar Threads | ||||
| SS2 card Jumper setting ? | bobit | Satellite PC Card Receivers & Internet by Satellite | 5 | 14-08-2005 07:33 AM |
| progdvb & ss2 help | andy-gi | Satellite PC Card Receivers & Internet by Satellite | 5 | 05-07-2005 06:24 PM |
| Sky+ recording problems | pjb | Sky+ (Plus) and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Sky+ Dual recording | net1 | Sky+ (Plus) and PVR Systems | 3 | 08-12-2003 06:49 PM |
| SS2 and DXR2 | refinechange | Satellite PC Card Receivers & Internet by Satellite | 0 | 23-06-2003 01:43 PM |
