Help on DVB dreamDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 04-02-2004 Location: London [South East]
My System: CPU IntelŪ PentiumŪ 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1.1mtr steerable dish Manhattan XT[CM, Quali 1080ir |
When I installed the DVB dream, I downloaded the tutorial from a link given to me by Bronking. I noticed in various info that DVB dream does not like the Technisat 4.3.0 drivers and works better with the older versions 4.2.8 or 4.2.10. I downloaded the 4.2.8 version together with K-Lite codec pack v2.7.0.0 and installed them. Previously before that I had done a search and although channels downloaded I did not get video or audio for obvious reasons. I then did a search on Telstar 12 @ 15w I then received video and audio, but it kept freezing or nothing. I then decided to try Hotbird @13 e which would be a long job anyway.However when I checked later [ much later] frequencies had been downloaded but not a single channel. My 1mtr dish is definitely on 13e as I checked with my sat receivers and I had pictures and sound, with 98 % signal. I keep reading through the tutorial, but cannot seem to grasp where I have gone wrong. And one last question can S2emu be used with DVB dream ? If any current users of DVB dream can help me, it would be very much appreciated, thanks guys | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | sorry m8, ive a quick play with this. and to be honest i don't think it's as good as progdvb (which you said didn't suit you, why?) i installed it and scanned hippysat which took over 5mins and then didn't pick anything up (and i know for certain that's where the dish is pointing) so maybe with abit of tweaking the software ide get it setup better, but over 5mins for scanning is to slow so i wont bother. if you look at poll results on this forum progdvb has over 60% of the vote compared to 13% for dvbdream that alone should tell you something. please consider going back to progdvb, and ask questions freely, you know the guy's here are only too willing to help if you put the work ingood luck | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
| | #3 | |||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | pick a time (not tonight, darts) (and not when mancity are playing) and i'm sure with the help of a few esteemed members we'll get it sorted bit by bit | ||
| | #5 | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | in the mean time chill out | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() Last edited by Sir Bronking; 09-03-2006 at 05:49 PM. | |||
| | #6 | |||
| | #7 | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | post a time then | ||
| | #8 | |||
| | #9 | |||
team lost 5-3 ) and whenever city play,available tonight, sat,sun,tues. dvbdream? i thought we were going for prog dvb what version ss2 software/driver? oh, and when your ready start a new thread entitled: aikon0029 diary progdvb ( that way someone searching dvb dream won't go down a blind alley | |||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() Last edited by Sir Bronking; 10-03-2006 at 04:43 PM. | ||||
| | #10 | |||
| | #11 | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | 1: contol panel>system>device manager> network adaptors> click on your card (see piccy of mine) click on drivers. what does it say? 2: what time? 3: post your replies on a postca....no sorry thinking of something else. ![]() start a new thread/post with your answers, i'll ask one of the mod's to close this thread now. | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() Last edited by Sir Bronking; 11-03-2006 at 05:55 PM. | |||
| | #12 | |||
| | #13 | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | latest progdvb 4.72.1 and lets see how we go and yes | ||
| | #14 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | That'll be fine ProgDvb 4.6.2 is OK for one of the later ones. By mutual consent then.... | ||
| dream, dvb |
Similar Threads | ||||
| X Dream TV encrypted in Dreamcrypt | net1 | Daily Satellite and Broadcast industry News | 1 | 13-01-2009 09:48 PM |
| How can i watch Free x tv, X dream ? | rolfw | Adult satellite channels | 8 | 06-08-2006 07:20 AM |
| Info on DVB DREAM | aikon0029 | Satellite PC Card Receivers & Internet by Satellite | 3 | 07-03-2006 10:20 AM |
| An idiots guide to DVB ? | Shaygate | Satellite PC Card Receivers & Internet by Satellite | 11 | 18-11-2004 11:25 PM |
| Threshold comparison of DVB cards | deeno | Satellite PC Card Receivers & Internet by Satellite | 3 | 12-08-2003 06:20 PM |
