aikon0029 diary progdvb
Old 11-03-2006   #1
aikon0029's Avatar
My System: CPU IntelŪ PentiumŪ 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1.1mtr steerable dish Manhattan XT[CM, Quali 1080ir
progdvb v 4.72.1 downloaded
aikon0029 is offline   Reply With Quote
Old 11-03-2006   #2
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
downloaded and installed or just downloaded?
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 11-03-2006   #3
aikon0029's Avatar
bronking, ready to go ahead when its conveniant for you
Old 11-03-2006   #4
no time like the present
we in safe hands lancelots with us
Old 11-03-2006   #5
aikon0029's Avatar
Sorry, just downloaded
Old 11-03-2006   #6
aikon0029's Avatar
by the way did not install, as that is one of my problems
Old 11-03-2006   #7
after download open and click exe what do you get?
Old 11-03-2006   #8
aikon0029's Avatar
It is headed Installation Progdvb Register Elcard filters select card/mode of progdvb and destination directory
Old 11-03-2006   #9
create a new folder call brand new begining and put progdvb zip file in it.
then unzip it there
look for exe file
click and run
select english
click on until piccy below
select card (see piccy)
click ok
run progdvb
post back
Old 11-03-2006   #10
sorry slow in typing click ok and i think it will ask you to select card next
Old 11-03-2006   #11
aikon0029's Avatar
Sorry and it also says
Old 11-03-2006   #12
btw yours will say destination C\progdvb mines tertv (terrestrial experiment)
Old 11-03-2006   #13
aikon0029's Avatar
clicked next and it has come up with Headed Installation Prog dvb and in the box it says Timeshift and 3 spaces to click Disable, In Memory, and In File before clicking next
Old 11-03-2006   #14
click next
Old 11-03-2006   #15
how we doing?
Old 11-03-2006   #16
aikon0029's Avatar
click next
sorry missed your posting about opening a new file, the next window after clicking Next says Modules
Old 11-03-2006   #17
aikon0029's Avatar
how we doing?
Did you get last quote it has come up with box saying Modules
Old 11-03-2006   #18
check its the same as me and click
Old 11-03-2006   #19
aikon0029's Avatar
how we doing?
I seem to be looking all over the place for messages not sure where I should be looking ???? sorry
Old 11-03-2006   #20
aikon0029's Avatar
Yes ok,same as you jpg
Old 11-03-2006   #21
aikon0029's Avatar
Now extracting files, now says Installation successfully completed, you can change device in settings Device list where to now please
Old 11-03-2006   #22
just stay here then after reading wait a min click pc cards at the top and back again you started the thread so suerly you can't get lost
right yes and let prog run, when its opened click on devices as shown in piccy
Old 11-03-2006   #23
aikon0029's Avatar
now come up with Sat position and DiSEqC
Old 11-03-2006   #24
can you give me a screen piccy
Old 11-03-2006   #25
aikon0029's Avatar
Sorry do not have a screen grab facility
aikon0029, diary, progdvb
Similar Threads
diseqc 1.2 and progdvb taynet Satellite PC Card Receivers & Internet by Satellite 5 08-03-2007 03:51 PM
progdvb & ss2 help andy-gi Satellite PC Card Receivers & Internet by Satellite 5 05-07-2005 06:24 PM
Progdvb Question? ripley607 Satellite PC Card Receivers & Internet by Satellite 1 02-03-2004 12:13 PM
Please help with progdvb and emu raemno Satellite PC Card Receivers & Internet by Satellite 1 19-01-2004 10:48 PM
ProgDVB and Multidec API darknebulae Satellite PC Card Receivers & Internet by Satellite 2 01-09-2003 11:01 AM
