I need some starter help plz!Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 14-03-2006 Location: Bath, United Kingdom
My System: AthonX 3700+ CPU ABIT KN8-SLI MB PNY Geforce 7800GT GPU SkyStar 2 PCI card 80cm Satellite Dish |
Hi all, this is my first post and hope my english is not too bad. This is my system: -AthlonX 3700+ -ABIT KN8-SLI -PNY Geforce 7800GT -160GB Hdd -512 RAM -Skystar 2 -80cm solid satellite dish, 2x 0.7dB LNBs, 6 deg brkt -4m f connection cable I have installed skystar 2 and connected it to the dish. Installed progDVB 4.72.2, and now I have a problem with setting up the dish. 1. Can anyone tell me how to position the dish and what is the difference when I have 2 LNBs? What does 28E mean physically? Am i correct to say that only 1 transponder per LNB, and so what happens if I want to swtich transponders? Do I have to rotate the dish manually? 2. I have heard that you can decrypt encrypted channels using software like s2emu and softcam. What is the risk of using this function? 3. What if I am not allowed to set the dish outside due landlord restriction. Is there another way to get the signals? 4. Is it possible to connect a normal TV aerial (via f-plug) and watch normal TV on the computer? Sorry for these newb questions, just want to sort all these out once and for all. Please help out! Any amount of advice is welcome. | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | welcome but this is not your first post you asked this question 1hr ago, please wait for answers and do not double post | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
My System: AthonX 3700+ CPU ABIT KN8-SLI MB PNY Geforce 7800GT GPU SkyStar 2 PCI card 80cm Satellite Dish | Sorry, my first post was a reply to some other post so I just want to make sure it is seen | ||
| | #4 | |||||||
Welcome to the forum at221 Like all s you are eager and enthusiastic but you really need to slow down a bit, you need to read relevant sections of the forum and you need to search for specific information using the above search routine. This after all is a self help forum. However you need to learn to walk before you try to start running
Or is your question asking what nuts and bolts do I need to loosen to rotate the dish? Please clarify
Ok that is enough answers for now, you really need to understand the basic things first so I suggest you start reading the various forums especially the stickie threads the ones with a red dot | |||||||
| | #5 | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | sorry topper over to u | ||
| | #6 | ||
My System: AthonX 3700+ CPU ABIT KN8-SLI MB PNY Geforce 7800GT GPU SkyStar 2 PCI card 80cm Satellite Dish | Thanks so much for the reply, I will keep looking at the "sticky" on the forum, but it would be great if you can tell me about point 3 and 4 as well. For point 1 I mean how to find a satellite. I never knew this was such a big topic, too much stuff to learn!!! | ||
| | #7 | |||
Regarding the possible restriction imposed by your landlord, I suggest you check with him first and see what the response is then take it from there. There is no point in speculating and giving advise until we know what we are dealing with Regarding 4 yes you can get a suitable pc card or USB stick see this thread here for the latter, you need to learn to navigate the forum effectively using the forum jump at the lower end of this page on the right to go to the parts of the board you need to read Nobody is going to spoonfeed you every answer to every question. | |||
| plz, starter |
Similar Threads | ||||
| Software for Technosat 5500 plz plz plz | Midnight | Receiver software, international Section | 7 | 02-08-2009 06:01 PM |
| plz i need help | WINXP | Receiver software, international Section | 1 | 12-02-2005 08:41 PM |
| Plz Plz Plz help me | Mighty Angel | Matrix Reloaded, Revolutions and CAS interface | 5 | 06-12-2004 06:38 PM |
| Plz Help , I'm totally new here ! (1simple question) | ZaBoY | Keys and Key editing | 0 | 06-04-2004 07:51 PM |
| PolSat key plz | Nokia9800 | Keys and Key editing | 1 | 24-12-2003 07:23 PM |
