softcameditorDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| skystar alcor1104 Join Date: 23-02-2006 Location: france
My System: PC xp sp2 with skystar2 on astra |
Hello everybody, Someone can tell how to use softcameeditor with softcam.key because my installation is ok but the keys are change and i don't understand how update them. Please help me Thanks best regards | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | In most cases you can just drop the new latest softcam on top of the old one, where it is will depend on which viewer you are using. | ||
My System: PC xp sp2 with skystar2 on astra | Thanks you for your response ok i ever find new keys on .ZIP format but i don't understand how insert them in softcameditor to update softcam.key | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Just unzip the file, then put the 'softcam.key' file into the Progdvb folder or into the MDplugins folder if you use MyTheatre. No need to use the editor at all. L. | ||
| | #5 | ||
My System: PC xp sp2 with skystar2 on astra | Thanks for your response only, i've breack my head for find but it's so simply. But what we can do with softcameditor? Best regards | ||
| | #6 | |||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad |
but you don't kneed it when you can download latest keys and as my learned collegues said | |||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | ||||
| | #8 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | They are in the same format for those two, the keys are the same for the same channel but they are in different formats for different recievers. L. | ||
| softcameditor |
