gizlog1.3 and twinhan pci card
Old 25-07-2003   #1
Hi all, i have read all the post that i can find regarding gizlog1.3 and twinhan pci card. However, gizlog still does not work for me. I intsalled gizlog1.3. I also use the thstreamreader03 from austech.info. I set the LOF1&2 = 10750000 (this for telstar 5 north america), fre= 10290000 (for TFC provider) and symbolrate= 20000000. Polarity= 0 (H). PID is the one i found from lyngsat, PID = 10FF. I also put the infor (MKH, HSN, PMK) from a valid card. Still, every time Gizlog run, it give me fail to open channel. I use the same set up with mytheatry, probDVB, johndec, winDTV and they all work and log well. Regarding the PID, is it the emm-PID or just the VPID provided by lyngsat? If anyone who succesfully test the gizlog1.3 and twinhan pci card, please help me. thank you in advance. by the way, i can log using twinlog and twinhan card. I then use the bin2log to convert the logged.bin to logged.txt. Never find any EMK keys. How do i know if i log garbage or not?
radiotech is offline   Reply With Quote
Old 18-08-2003   #2
TwinHan DST-CI PID = 1F00
Hello,
I've download WinData 1.5 from http://www.twinhan.com/english/suppo...d/download.htm
I need only to receive internet using PID = 1F00
The PID (Filter Options) disabled and can't be changed in this version
Please advice any way to do this usin TwinHan DST-CI PCI-Card
Thanks.
-----------------------------------SameMessageButDetailed-----------------------------------
Hello,
I really need to change the filter option in WinData 1.5 from (Use the MAC address of the hardware) which is default to (Calculate MAC address from IP address of Dial-up connection) to use the DST-CI with www.OrbitPlus.net which is originally configured to use B2C2 software with SR2045U unit to receive internet via satellite ArabSat 3A
I guess the IP option will be loaded automatic but still need to change (The Filter Options) which disabled in WinData 1.5 and can not change the defaults , Please advice how to enable changing it because it's required also to set Unicast PID to 0x1F00 or www.orbitplus.net data receive will not work using Nortel VPN client or Windows XP Professional VPN connection.
Regards,
Aziz
aziz is offline   Reply With Quote
card, gizlog13, pci, twinhan
Similar Threads
Visionplus VP1030 PCI Card grex23 Satellite PC Card Receivers & Internet by Satellite 14 13-03-2005 02:43 PM
Please be gentle.............. pm1961 Satellite PC Card Receivers & Internet by Satellite 1 21-01-2004 10:01 PM
