Skystar 2 affecting my audio...Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 14-03-2006 Location: Bath, United Kingdom
My System: AthonX 3700+ CPU ABIT KN8-SLI MB PNY Geforce 7800GT GPU SkyStar 2 PCI card 80cm Satellite Dish |
I installed my skystar 2 card but when it is enabled, the audio on my system is abit laggy (i.e. when i play an mp3 using windows media player 9 the music is laggy and slow). When i disabled it I played the same mp3 and its normal again. What is the matter?? Thx for any help~~ | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | sounds (pardon the pun ) like a comp prob (speed)rather than ss2 | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
| Regular Member Join Date: 09-12-2003
| hi I have the same issue, I usually just leave progdvb running with the sound turned down and its ok to play media files without lag then. A point though is that I have a decent spec PC (P4 3.06mhz,1gb ram) so it dosn't affect performance. Neillers | ||
| Location Ireland. Current Setup:Homebrew PC, 3.06 P4.1GB ram Skystar 2 + Moteck SG2100 + 1.1m dish. Soon to be a dreambox monster | |||
| Member Join Date: 14-10-2007 Location: UK
My System: Skystar 2 amd 64 4200+ Vista 64 | I have the same problem I use dvbviewer and have to have it running in the background to play any sound or watch dvd's etc.. Otherwise I get pops and crackles. If I disable the ss2 driver the problem disappears. BTW. I hate people who blindly guess on these forums and come out with ridiculous replies like. "sounds (pardon the pun ) like a comp prob (speed)rather than ss2" I am running an AMD 64 X2 Dual Core 4200+ so no it's not a speed PROB! | ||
| affecting, audio, skystar |
Similar Threads | ||||
| 123sat audio quality | Shahid | Transponders & channels | 2 | 20-10-2007 02:03 PM |
| Transponder update 31/07/03 | Satdude | Transponders & channels | 1 | 11-08-2005 03:18 AM |
| Skystar 2 | Homebrew | Satellite PC Card Receivers & Internet by Satellite | 5 | 09-01-2004 10:34 PM |
| Best video qualtity, Skystar 1 or 2? | mtiller | Satellite PC Card Receivers & Internet by Satellite | 13 | 03-12-2003 09:30 PM |
| Skystar 2 not working properly | ckrys1 | Satellite PC Card Receivers & Internet by Satellite | 11 | 31-10-2003 10:54 PM |
