Thinking of geting a SS2 PCI card so questionsDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Guest
Posts: n/a
Thinking of geting a SS2 PCI card some questions, Any one have this card if so what is it like also what is the best software to run it, also can i use a my card programmer as are card reader also where is the cheapest and best please to buy, thanks | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | i have ss2 and am very pleased with it progdvb (in my oppinion is the best viewer) once you get to grips with it it's quite easy to use. as for buying there are many places so search and you shall find | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
| skystar alcor1104 Join Date: 23-02-2006 Location: france
My System: PC xp sp2 with skystar2 on astra | Hello, I use a skystar 2 and i' mhappy with and the Progdvb programs to run with it. The both are really simply to use and fit but i m a not a old user so i don't know if the others system are better | ||
| Member Join Date: 15-03-2006 Location: greece
My System: SS2 usb | Hello to all I am an new user of the SS2 usb I feel that it is a good buy U can use infinity usb/phoenix http://www.infinityusb.com/ or a similar programmer/smartmouse with it For those who have the SS2 already could u take a look at this http://www.satellites.co.uk/php-bin/...262#post316262 and tell me what u think? | ||
| card, geting, pci, questions, ss2, thinking |
Similar Threads | ||||
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| SS2 card Jumper setting ? | bobit | Satellite PC Card Receivers & Internet by Satellite | 5 | 14-08-2005 07:33 AM |
| What Modem Pci Card do Netsystems use? | Mr G | Satellite PC Card Receivers & Internet by Satellite | 1 | 06-12-2003 01:47 AM |
| SAt pci card ? ? ? | MasterAbacus | Satellite PC Card Receivers & Internet by Satellite | 3 | 19-09-2003 12:25 AM |
| gizlog1.3 and twinhan pci card | radiotech | Satellite PC Card Receivers & Internet by Satellite | 1 | 18-08-2003 08:47 PM |
