help .. my motor dilema
Old 17-03-2006   #1
expert ..... in nothing
My System: dreambox 500s art card
so i have a 1 metre dish , asat motor
everything was fine , moved the whole dish/mount to a better place
now my pc cant move the damn thing , it will move via the buttons on the motor . i reinstalled windows still nothing , so i took every wire out redone the lot . nothing , so i dismanteled the lot made a 6 inch patch cable tried the motor infront of the pc only moved via the buttons on the motor itself
the picture off the satelitte is fine just wont accept any movement commands
so im returning it tomorrow ,
any last idea s ?
georgefromasda is offline   Reply With Quote
Old 17-03-2006   #2
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
I am not sure I can identify the problem like this, but it seems to me that the motor driver (software) is not functioning. Normally,for small dishes this is performed by the diseqc driver, and most likely that your receiver needs these settings to be re entered. It could be that the plugin needs reinstalling or even more simply a box ticked.
Tell us a bit more about your receiver, and if you come accross the disecq issue.
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 17-03-2006   #3
im using prog dvb , my pc does everything , i even reibnstalled xp just to be sure .
never had a diseqc problem before , used dixie , kadiseqc and diseqc 12
Old 18-03-2006   #4
The motor was checked infront of me and it was ok
I replaced the 450 w with a 600w psu in the pc , (ran the 450 as a secon psu works well)
redone the whole dish thing
still nothing
dixie
diseqc 12
kadiseqc
any ideas people as im really losing it
any known software inconpatabilities ?
Old 18-03-2006   #5
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
have you changed any software (i do'nt mean windows)
and when you did change windows have you sorted skynet.sys in system
read post 20
here
these are compatable
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 18-03-2006   #6
are they only for skystar cards ?
if not ill give them a go
thank s
Old 18-03-2006   #7
no joy
Old 18-03-2006   #8
well i done a full reinstall of xp (new disk)
installed mininum drivers , no av or firewall
still no joy
Old 19-03-2006   #9
i spent last night making a new tower
2.8 ath xp 512 ddr asus mobo ati vga
still the same
this is the card btw
hp://ww.technotrend.de/english/download/tt-dvbsat-pci.jpg
*edit*
just remembered i had a 2 port isolation switch which i dont use
regardless to say that has just been disconnected andf it still wont drive
**edit*
so it must be the pci card , possibly would a diseqc switch do the job ?
btw i used to own 2 computer shops and i still sell pcs thats why i have all the hardware / software
Old 20-03-2006   #10
i take it youve read and already done this?
Notes for this version
First, you must close all DVB applications.
Then save the new version on your PC and extract the files into a new folder.
For the new software you must also update the drivers for your DVB-card.
If you use Windows 98, you will need the CD named "Installations - CD for MS- Windows 98"
Open your "Device Manager" and look for the topic "network cards" and
"remove"/ "deinstall" the device "Virtual DVB-S/-C/-T Network Adapter".
Look for:
"TechnoTrend - TT-DVBsat PCI" or "TechnoTrend - TT-PCline premium" then
choose "drivers update" on the tab "Driver" and
follow the instructions of the operating system.
You can find the new driver-information and the new drivers
in the main folder of your new installation
(the folder you extracted the new files to).
Please use the function "Remove" on the tab
"Start"-"Settings"-"Control Panel"-"Software" for the software
"TT-PCline premium" first.
Restart your PC, then run the file "setup.exe" to install the new software.
Follow the instructions of the installation.
Old 20-03-2006   #11
just tried it again
still not working
thanks bronking
ill make a partition and try win me
you never know
Old 20-03-2006   #12
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
Which drivers are you using for the card there ? 2.17g ??
Odd this one.
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 21-03-2006   #13
Odd this one.
L.
hi lancelot
im using 217s
i have also tried 219s
no joy
Old 21-03-2006   #14
kinda come to a conclusion
1 its not the motor (it moves via the switches on it and ive seen another reciever move it )
2 its not the wiring , totally replaced and all new f plugs (signal on hotbird 100%)
3 its not the psu (had 2 working on the pc)
4 its not the pc , tried 1 other and built a new one to try it (also windows)
5 all drivers and diseqc software tried different combos
6 even a different dish has been tried
for the first time in ages im beaten .
so my only ideas left
1 new sat card / reciever (id like a dreambox )
2 new motor
thanks for the help guys the wifes patence is only so strong and shes not happy over the time im spending on the sat and its not working
i think ill just stick to a static dish
thanks
Old 21-03-2006   #15
Lancelot's Avatar
New motor sounds good
36V H-H with a Vbox will sort it. With 99 memories and a remote control, it will futureproof your system if you ever want a larger dish and they're generally a sturdier arrangement.
I've always run this way as I prefer manual rather than auto on the whole.
Rgds
L.
Old 21-03-2006   #16
can only echo what lanceloy said,
there so much less strain on cable, pc card and cpu that the difference/performance is very evident
Old 21-03-2006   #17
36v hhmmm
thanks people
anyone want to buy a asat motor , sort of works
actually i was thinking of a small manual diseqc switch
Old 21-03-2006   #18
Lancelot's Avatar
Switch for what sorry?
Do you mean for use with another reciever as well.
L.
Old 21-03-2006   #19
L.
no,i dont know what its called , sends a east/west diseqc signal to the motor (30 quid at merseysat) its not a 36 v one its a coax only connection
Old 22-03-2006   #20
rotor control
got one and it worked for a whole 10 minutes
now its useless !
Old 22-03-2006   #21
now think apart from moving the dish etc did you change anything on your computor, ie: update anything, driver, software.
because otherwise it's phyical/mechanical and according to you youve checked every thing
and you said it worked with another reciever?
Old 22-03-2006   #22
BGonaSTICK's Avatar
If it's not an intermittant fault on the motor, I'm going to stick my neck out and say that it has to be the physical card based on everything else you've tried. The proof of the pudding would be to borrow a DiSEqC receiver and have it on test at your place for a couple of days.
Could be loads of other stuff though. Did you power off the PC before messing with it all in the first place?
Did you maybe short something?
Maybe there's some water in either your coax or possibly even the LNB?
Can you perform a 'factory reset' on the motor?
Have the east/west limit stops moved?
Whatever it is, a loan of a new STB will tell you which half (inside or outside) the problem lies in.
STICK
Old 23-03-2006   #23
got it going last night
dont know how , goes east and west only by the rotor switch
the card must be damaged because this does exactly what the card does (movement wise) all this now tps has gone
why me ?
Old 23-03-2006   #24
Lancelot's Avatar
TPS hasn't gone yet !!
Cheer up george
L.
Old 23-03-2006   #25
why me ?
i sometimes wonder whether we're(as in this website) is a cure or reason for mental instability and depression
george take a sulk pill and come on m8, let's get going
dilema, motor
