Need help on encryption
Old 18-03-2006   #1
My System: AthonX 3700+ CPU ABIT KN8-SLI MB PNY Geforce 7800GT GPU SkyStar 2 PCI card 80cm Satellite Dish
My uncertainty is divided into three main parts:
1) I have just setup up my 80cm dish and SS2 card and got signal of about 30% -> 60% quality. Is this normal? Also, my signal bar sometimes keep going off and on again. Is this due to wind or bad connections?
2) I am locked onto astra 19.5E, does it include all the astra transponders i.e. astra 2A, 2B, 1C...etc. so when I scan using progDVB I scan all possible astra?
3) I am a football addict and I really want to know which channels in astra have live football matches... like premiership and la liga(barca). If they are encrypted can you tell me what is the best way to decrypt these channels?
I will be greatful for any help you can give me.
Any amount of advice is welcome!
Cheers~
Moved to this section as it may get more response - Admin
at221 is offline   Reply With Quote
Old 18-03-2006   #2
wolfav's Avatar
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter
hi m8 im assuming you mean a skystar2 if this is what you have i think there is some files out there for that to open up some channels on astra that show footie films etc as for your signel it could be a bad connection or your dish may need the minimal of movements if you goto satnet or satkeys you should be able to get the relevant files to open up some of the channels available
good luck and happy viewing
wolfav is offline   Reply With Quote
Old 18-03-2006   #3
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
is it locked on astra because that's what you want?
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 19-03-2006   #4
Post Meister
BarMoo's Avatar
My System: 2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss
No. Astra 1 is 19° Astra 2 is 28.2° - so you only scan whatever fleet of satellites your antenna is actually pointing to at the time. In your case 19°E. (see Lyngsat) for the whole fleet.
Mark.
Have Fun, Moo.
BarMoo is offline   Reply With Quote
encryption
Similar Threads
Morrocan palace "complains about TPS encryption changes" easysat Daily Satellite and Broadcast industry News 6 16-05-2005 11:34 PM
Premier Sport Encryption? meldrew Jimbo's Football and Sport 1 20-01-2004 02:23 PM
FREE-XTV encryption Update nobbly Adult satellite channels 0 10-07-2003 10:09 AM
BBC encryption ends Thursday 10th July net1 Sky Digital (BSkyB) and Astra 28.2 East General 0 08-07-2003 09:05 PM
Premiere to employ new encryption format sooner than expected! net1 Daily Satellite and Broadcast industry News 0 04-05-2003 10:24 PM
