Skystar 2 with Progdvb questionsDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Dream-Believer Join Date: 30-01-2006 Location: Guernsey Channel Islands
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w |
I have just installed a Skystar 2 card with Progdvb. I have done a channel scan pointing at 19.2 e , it has found a load of channels like, taquilla, canal+, cartoon network, mtv etc, which is great!. I was wondering if I can manually enter channels without disturbing the channels It has already found?. I was hoping there would be more english channels!!. Thanks in advance. | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | when you say manually enter channels, do you mean manually enter transponder scan, if so the answers yes, click channel list then scan transponder input what you want select scan if it fids anything it will list them cklick ok wait a couple of secs for it to update then it will be added to your existing list | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w | Not sure about transponder scan?, all I want to do really is try and obtain a list of channels and freq avaliable on 19.2 deg and enter some editional channels. I dont want to rescan for more channels and loose the channels I have alread found. When watching a channel the quality bar is display (channel vary) between 59- 79 %, is that ok. Thanks. | ||
| progdvb, questions, skystar |
Similar Threads | ||||
| SkyStar 2 and Diseqc questions.. | Lucifer | Satellite PC Card Receivers & Internet by Satellite | 0 | 02-07-2004 04:44 PM |
| Progdvb Question? | ripley607 | Satellite PC Card Receivers & Internet by Satellite | 1 | 02-03-2004 12:13 PM |
| Please help with progdvb and emu | raemno | Satellite PC Card Receivers & Internet by Satellite | 1 | 19-01-2004 10:48 PM |
| Skystar 2 | Homebrew | Satellite PC Card Receivers & Internet by Satellite | 5 | 09-01-2004 10:34 PM |
| Skystar 2 not working properly | ckrys1 | Satellite PC Card Receivers & Internet by Satellite | 11 | 31-10-2003 10:54 PM |
