Any Viewer To Work With PCTV 400e USB?
Old 20-03-2006   #1
My System: SS2 ProgDVB 4.56.2 Pentium IV
hi there,
got a Pinnacle PCTV 400e USB card: i've tried different versions of ProgDVB and MyTheatre, but none seems to recognize this new USB device.. has anyone managed to put this particular card model to good use?
cheers
Jahr2k6 is offline   Reply With Quote
Old 16-06-2006   #2
Thumbs up sorted!
OK, all sorted now!
I finally got ProgDVB v. 4.73 up and running on PCTV 400e USB... importing TuningSpace.reg into the registry was the first thing... but I also needed to add an extra library file (PclePctv400e.dll), and 3 extra modules (BDA.device, DVBSTuner.device, and IsAvailable.device), all downloadable from the following site:
h**p://pctvsat.free.fr/viewtopic.php?t=2684&sid=7de59f87c9105249cfcb4330f 8271d9b
once you got all you need, the setting-up is actually quite straight-forward:
1) you just need to install ProgDVB without selecting any card mode (just choose the --not start device-- option), check Register Elecard filters for software mode, and finally choose not to start ProgDVB after installation completes
2) once you've installed ProgDVB, copy the PclePctv400e.dll library file in the C:\ProgDVB folder, and copy the 3 extra modules (BDA.device, DVBSTuner.device, IsAvailable.device) in the \Modules subfolder
3) start ProgDVB, select Settings -> Device List, and Start DVB LifeView... then, you should be able to start DVB-S Tuning-Space (BDA.device)
(if DVB-S Tuning-Space doesn't start, try stopping DVB LifeView: sometimes you just needle to feedle a bit with this setting... but eventually you should be able to start the BDA device)
and that's it: once DVB-S Tuning-Space is started, the reception quality level will be displayed... so you can finally select your satellites, and perform a scan...
ProgDVB works so much better than Media Center, i'm so glad i can finally get rid of Pinnacle's software!
Old 16-06-2006   #3
Amo Amas Amant Admin
Topper's Avatar
Good
Thanks for that Jahr2k6
I am sure others will benefit from your informative post
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 20-06-2006   #4
Folding*home
Prophessor's Avatar
My System: [ Relook 250S ]
Great thread.
Jahr2k6, whats the picture like and does it take too much out of the cpu?
When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork."
Prophessor is offline   Reply With Quote
Old 20-06-2006   #5
the image looks pretty good: even using just the built-in elecard filters, it looks pretty much like DVD-quality video... and, of course, the mpeg2 video capture files that you get when you record are pretty much as good... for sure much better than the video quality i was getting with the pinnacle software...
i've tried both USB and PCI cards, and i would say that on PCTV400e ProgDVB's performance is at least as good as it is on SkyStar2...
CPU usage stays between 30 and 40% (that's on a Pentium 4 at 2.8GHz), which is OK, just comparable to other viewers...
400e, pctv, usb, viewer, work
Similar Threads
Will USB - Serial Cable work? Which Reciever? ViReN Receiver software, international Section 8 31-07-2006 08:45 PM
infinity usb pheonix and titanium fasta Cards & Programmers General 3 24-02-2004 12:21 AM
ican someone give me instruction.problem with infinity usb phoenix fotisbak Cards & Programmers General 2 17-02-2004 11:43 AM
Sky Remote No Work! homerjay Sky Digital (BSkyB) and Astra 28.2 East General 6 18-11-2003 10:19 PM
will this etup work?!? FoneFreak Satellite PC Card Receivers & Internet by Satellite 3 21-09-2003 09:56 PM
