thank you very much
Old 25-03-2006   #1
Part Timer
don'tknowdon'taskme's Avatar
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
thank you very much
a very big thank you to bronking and lancelot for there thread on setting up a pc sky card it helped me a hell of a lot as i was wondering were to start for a fortnite.the thing i can't understand is when i click on a channel i have a popup which says:error filter not found
elecard_mpeg2_video_decoder
what it means i don't know and then i press ok and the channel starts.again a very big thank you guys.
If it is not broke fix it till it is
don'tknowdon'taskme is offline   Reply With Quote
Old 25-03-2006   #2
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
not sure but....
click on settings
then audio and video
then direct show
what do u see
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 25-03-2006   #3
BGonaSTICK's Avatar
The installation of the elecard codec is an install-time option with most recent versions of progDVB IIRC and if that's what you're using.
Old 26-03-2006   #4
Part Timer
no bronking have the same settings as shown yet same popup still pops up .NEXT, i haven't got a clue.it still works and shows the odd smabled channel but why does it show that pop up.
Old 26-03-2006   #5
screen print/ picture please
which progdvb version?
when you installed progdvb did you have this
Old 26-03-2006   #6
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
C:\progdvb\filters.
Click on the elecard reg proggy and restart progdvb.
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 26-03-2006   #7
Part Timer
Originally Posted by Lancelot
C:\progdvb\filters.
L.
thank you sorted first time very well done guys first class.is that the only keys you can enter or are there more i had the understanding you can open a lot more with the ss2 then with a stb.
Old 26-03-2006   #8
go here for plugins for progdvb s2emu 1.22,v plug etc
if you read aikon's diary there's info there (a lot of which you'll know) but make a brew and digest
