Help plz, Skystar2 tuner
Old 26-03-2006   #1
SLZ
SLZ's Avatar
Hi guys,
problem: Skystar2 Rev.2.6D doesn't tune to high band frequency (frequencies like 12597) but all other functions are 100% OK (it was working perfect at the time of purchase)!
Othe info: Tuner 14/18V ok, LNB ok, cable ok, everything ok and checked.
Driver Ver: 4.3.2 and I have checked almost all other drivers!
PC info: 2.4Ghz Intel, 512M ram and other suitable requirments for ss2.
Please help!!
Please help!!
SLZ is offline   Reply With Quote
Old 26-03-2006   #2
rolfw's Avatar
Real name: Rolf
What is the highest frequency you can tune to? Check that the 22Khz tone has not been accidentally toggled to off.
Rolf
Old 26-03-2006   #3
SLZ
SLZ's Avatar
11919 Mhz is the highest tunable frequency (on hotbird). 22khz is on (I tested it using a variety of tuner programs like "b2c2 tunner control" and "progDVB"). I wish somebody would tell me how to make additional checks on 22khz tone, including a way to test it; without using osiloscope.
Thanks.
Old 26-03-2006   #4
rolfw's Avatar
Real name: Rolf
That sounds like it isn't working then, or could of course be the LNB.
Rolf
Old 26-03-2006   #5
SLZ
SLZ's Avatar
Dear Rolf;
My "Starsat" receiver receives all channels using this LNB and dish! (and shows signal quality of above 50%).
Old 26-03-2006   #6
rolfw's Avatar
Real name: Rolf
OK, we can rule out the LNb then. Can't remember the software as I haven't used mine for a while, but is there a transition figure that can be changed for switching to upper band?
Rolf
Old 26-03-2006   #7
SLZ
SLZ's Avatar
Transition figure? would you explain more? is it something like, say a radio button in softwares which enable/disable 22khz?
Old 26-03-2006   #8
rolfw's Avatar
Real name: Rolf
No, I think that it is actually called 22Khz transition, it is normally set at 11,650, it is the figure at which the receiver is told to switch to upper band.
Rolf
Old 26-03-2006   #9
SLZ
SLZ's Avatar
Sorry, I have no idea about that. The last thing I have decided to do is to get someone solder out EEprom of the card and reprogram it! I have even downloaded the datasheet of eeprom! but finding a suitable programmer is really an issue!
Old 26-03-2006   #10
rolfw's Avatar
Real name: Rolf
What viewing software are you using?
Rolf
Old 26-03-2006   #11
SLZ
SLZ's Avatar
ProgDVB ver: 4.71.5 and DVBviewer, both act the same. I usually test it with "fast sat finder" which shows 0% signal on High band!
The card was ok at the time I bought it and I received more that 1200 channels on hotbird, then I pointed my dish to UtilsatW3 in order to do "offline-downloading". I did it for about one month without any problems but when I turned dish to Hotbird again, high band was gone! I wanna cry
Help please
Old 26-03-2006   #12
rolfw's Avatar
Real name: Rolf
The setting is called switch in the LNB setup menu.
Rolf
Old 26-03-2006   #13
SLZ
SLZ's Avatar
I got it, you mean "local ocillator" of the lnb which is 10600 mhz for high band and swithc 11700. Anyway, the settings are ok, I checked them again. Why there is no crying smili at this forum?
Old 26-03-2006   #14
rolfw's Avatar
Real name: Rolf
No, I mean the one in the middle, "Switch".
Rolf
Old 26-03-2006   #15
SLZ
SLZ's Avatar
Swithc 11700 ok, power: checked, Lof1: 9750, LOF2: 10600, KU band.
I dont know what on earth happend to this poor skystar! I even installed my card to my brothers computer who has the same card, his card functions good but mine is useless at high band
Old 26-03-2006   #16
rolfw's Avatar
Real name: Rolf
That being the case, it is probably a case for the bin, unless you bought it less than a year ago in the UK, or 2 years in Europe.
Rolf
Old 26-03-2006   #17
My System: Various
Maybe it's a damaged coil?
'Technisat Skystar2 KuBand switch problem' h**p://joshyfun.blogspot.com/
Orthoclipse is offline   Reply With Quote
Old 26-03-2006   #18
SLZ
SLZ's Avatar
Thanks alot for you attention guys, I think final solution is purchasing another one, the bad point is that I live in Iran where even owning ss2 is considers a crime!!
Old 26-03-2006   #19
rolfw's Avatar
Real name: Rolf
Well looks like replacement of the coil is not that difficult to an electronics engineer, but have to say that I wouldn't try it, still remember my last effort. may be worth trying to source the component though, or alternatively a 22Khx tone inserter, they are not very expensive. http://www.donberg.ie/descript/t/toninert.htm
Rolf
Old 26-03-2006   #20
SLZ
SLZ's Avatar
Dear Rolf and Orthoclipse;
Thank you very much for the care you have taken to solve my problem.
I am going to change coil right now and I have found almost a same coil in a broken computer-power-supply.
I will keep you informed about the results.
Sincerely
Old 26-03-2006   #21
SLZ
SLZ's Avatar
Guys, I soldered out the mentioned coil and soldered what ever 1mH coils available I had, guess what!? Nothing! then I soldered 2 wires to the bases of the coil and tested near 30 coils!!!!! nothing happend to high band, finally I opened shell of original coil but wires seemed to be ok and no sign of burning or overheating was visible! so I soldered the original coil to the board again. The PDF file I downloaded exactly explaines my problem but mine seems to be more complicated, for the coil is not the component to be blamed!! I will highly welcome any other suggestions.
Old 28-03-2006   #22
SLZ
SLZ's Avatar
Thumbs up Conclusion
I am writing this final post for those who may encounter the same problem.
If you are sure that your dish, lnb and other equipment are 100%ok and all software settings are correct, then you can proceed to test your hardware (Skystar). Because most of the components on this card are SMD (surface Mountable Device), they may easily became disconnected from board by smallest force withought any visible symptoms. so, look at Mr.Albert Houwer's description of coil replacement at http://joshyfun.blogspot.com (only if you are experienced enough with electronic boards and soldering), then if that was not the case, look at the nearby component for defection. In my case, one miniature resistor, 220ohms, R17 was a little above the board! bringing me alot of trouble and preventing the card from receiving high band.
Hereby I want to thank Rolfw and Orthoclipse for their guides to me and my especial thanks to Mr. Albert Houwer whose instructions lead to solving my problem.
Old 28-03-2006   #23
rolfw's Avatar
Real name: Rolf
Well done, nice to hear a satisfactory conclusion.
Rolf
Old 10-06-2006   #24
My System: computer
Thanks For Info
i have same problem with my ss2 and 22khz tone
after read post here i find the problem
is resistor R17 and now 22kzh work
THANKS
panttt is offline   Reply With Quote
Old 16-10-2006   #25
My System: Pentium III Skystar2
hello, first thanks to all on your information..
I have the same problem with my ss2 - the coil was faulty, and I changed it.The capacitor near it (10V,100uF) was also faulty and I changed it (I put 16V,100uF).Everything else works fine except 22kHz. Does anyone know where is the source of 22kHz signal, on the board? Or what else could be problem? Just to mention, coaxial cable was short-circuited and it was the main source of problems
Thanks for any info
epsilon_ is offline   Reply With Quote
plz, skystar2, tuner
Similar Threads
About SkyStar2 With B2C2 Shipset ......Question? tabozada Satellite PC Card Receivers & Internet by Satellite 6 19-04-2006 10:03 PM
SkyStar2 - what channels on Astra 19.2E ? Rod Hulls Aerial Satellite PC Card Receivers & Internet by Satellite 9 01-03-2004 09:08 PM
Watch Cryptoworks channels with SkyStar2 PCi alexyug Satellite PC Card Receivers & Internet by Satellite 1 23-02-2004 09:45 AM
PolSat key plz Nokia9800 Keys and Key editing 1 24-12-2003 07:23 PM
SkyStar2 what channels?! FoneFreak Transponders & channels 4 20-09-2003 01:00 PM
