Elecard ProgDVB
Old 28-03-2006   #1
My System: Manhattan ST 550, Nokia 9800s, 1.2mtr dish controlled by Uniden, SuperJack, Nokia 85cm motor driven SatScan dish. Plus Skystar2, and many other bits from analogue days.
Elecard ProgDVB
Hi can anyone tell me why when I select a channel in ProgDVB I have to OK "ProgDVB Engine" dialog box that says "error Elecard_MPEG2_Video_Decoder not found" after OK channel comes up, the above filter appears to be in ProgDVB Filters. still getting to grips with this prog. but it seems very good, and runs my Moteck without fault.
Chris.
SnapperChris is offline   Reply With Quote
Old 28-03-2006   #2
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
see http://www.satellites.co.uk/php-bin/...ad.php?t=59506
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 29-03-2006   #3
Thanks bronking for the re-direction, I tried clicking on the file, and said yes, but I'm afraid it did'nt work for me!
Chris.
Old 29-03-2006   #4
when i go into the root folder of progdvb i get as piccys
1 showing folders
2showing whats in c:\progdvb\filters
3showing whats in c:\progdvb\filter graphs
does yours look the same (show piccy's if you can)
if not 2 options reinstall progdvb and make sure ....(see piccy4)
if that doesn't work and yours is still dif maybe i can zipp my folders to you?
Old 29-03-2006   #5
Hi bronking, I re installed and checked boxes as you suggested, and IT WORKS, perhaps I missed them on first install, can't thank you enough, this is the first thing that has gone right today, software for controlling my camera was working the other day, today it dos'nt, pin bent in my CompactFlash card reader, straightened it out (as I've done before) this time it refuses to read, crap reader to start with, older ones had deep throat, so card was always straight. oh well perhaps I'll try mowing the lawn tomorrow, bet mower breaks, thanks again Chris.
Old 29-03-2006   #6
no probs m8 well done
elecard, progdvb
Similar Threads
diseqc 1.2 and progdvb taynet Satellite PC Card Receivers & Internet by Satellite 5 08-03-2007 03:51 PM
progdvb & ss2 help andy-gi Satellite PC Card Receivers & Internet by Satellite 5 05-07-2005 06:24 PM
Progdvb Question? ripley607 Satellite PC Card Receivers & Internet by Satellite 1 02-03-2004 12:13 PM
Please help with progdvb and emu raemno Satellite PC Card Receivers & Internet by Satellite 1 19-01-2004 10:48 PM
ProgDVB and Multidec API darknebulae Satellite PC Card Receivers & Internet by Satellite 2 01-09-2003 11:01 AM
