Progdvb crashingDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 12-06-2003
Hi, I'm running the latest Progdvb with a Skystar2 pci on a P4 2.8ghz, 1gb Memory. My problem is that between switching channels or scanning etc, sometimes it goes into 'not responding' an comes back after a pause, other times it just crashes completely. Would the 4.62 version be more stable? (not that I can find the 4.62!!) Regards Kyliesat | ||
| Member Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | progdvb 4.62 is more stable if you want to try it | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
| Thanks Bronking, I tried replacing ProgDvbEngine.dll but get this error. ProgDVB.exe The procedure point @Device_IsStreamSource@4 could not be located in the dynamic link library ProgDvbEngine.dll Any ideas? Thanks | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | are we talking about 4.62? or is this the prob you had originally? if it is, uninstall latest prog. install 4.62 (ProgDvbEngine.dll) should be in the root folder of progdvb. is it there tip: when asking questions show piccys (prt scr) and make sure your profile is up to date Join Date: 12-06-2003 Posts: 29 is not a lot to go on | ||
![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() Last edited by Sir Bronking; 01-04-2006 at 12:22 PM. | |||
| crashing, progdvb |
Similar Threads | ||||
| diseqc 1.2 and progdvb | taynet | Satellite PC Card Receivers & Internet by Satellite | 5 | 08-03-2007 03:51 PM |
| progdvb & ss2 help | andy-gi | Satellite PC Card Receivers & Internet by Satellite | 5 | 05-07-2005 06:24 PM |
| Progdvb Question? | ripley607 | Satellite PC Card Receivers & Internet by Satellite | 1 | 02-03-2004 12:13 PM |
| Please help with progdvb and emu | raemno | Satellite PC Card Receivers & Internet by Satellite | 1 | 19-01-2004 10:48 PM |
| ProgDVB and Multidec API | darknebulae | Satellite PC Card Receivers & Internet by Satellite | 2 | 01-09-2003 11:01 AM |
