*.DVB & *.SDXDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish |
Where can i download up-to-date DVB files, i can find SDX but i cant import them to progdvb (or can i?) Cheers | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Been looking round for the information, but can't find anything relevant. I don't use ProgDVB myself, but you may try looking HERE | ||
| | #5 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Anyone got any more news on this? Folks must import channel data into ProgDVB? Could someone post their ProgDVB 'Channel' subfolder here? I'm after reasonably up-to-date versions of 19.2E through 1W. Either that, or can someone tell me an easier way of scanning than a single transponder at a time? I'm on V4.40.3 Cheers. | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | This file has a fairly up-to-date ini list. Replace any or all of your ini files in Progdvb with them. Llew | ||
| | #7 | ||
My System: Dreambox 7000, Skystar2 | I think the transponder list I have is not too old as it's a very new release, but there are no channels loaded and I only seem to be able to scan one transponder at a time. I figure I have less that 50 years to live (max), and therefore not enough time to scan all the transponders on all the satellites I want. Do you have ProgDVB and could you post the 'Channels' subfolder? Respect. STICK. | ||
| | #8 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Why would you need a new Channel subfolder? Not sure what you mean by "only able to scan one transponder" -you need to go to Settings/Disecq/click on whatever Sat. is listed, click List, choose your satellite of choice, click OK, go to Channel List, Channel Search, and away you go. Llew | ||
| | #10 | ||
My System: Dreambox 7000, Skystar2 | OK. Seems to be scanning OK, but consider this... I have a diseqc motorised dish, but not postioned by this receiver. No, really. So all satellites are effectively on LNB 1, but I don't have any need of any of the diseqc settings on this PC. I've not finished fiddling with it yet, but how am I going to get all 15-odd satellites assigned to LNB1 for scanning purposes? Sorry to sound like a wingnut, but in my 'naitive' MT2.76, you can just assign a sat to a given LNB, and the diseqc commands are managed externally in a plugin. | ||
| | #11 | ||
| Guest
Posts: n/a
| Just go to settings and set the perimeters ,it even has DiSEcQ 2 listed . ![]() --------- PS: I just put ProgDVB on a SmartMedia card 32mb and its stable and running perfectly. with 20mb leftover! ha hah ![]() But MT 2.76 wont do that too good. | ||
| dvb, sdx |
