Skystar 2 not working properly
Old 15-08-2003   #1
Had skystar 2 for 3 weeks- worked fine till yesterday- now signal is much reduced ie on Astra gets 8% signal on channels that last week got 50%, using same dish/lnb/cable. Same set up gets me full signal on other sat receiver. Result is that even strong signals on astra eg Eurosport are not receivable with skystar at all despite same dish/lnb/cable receivable with ease by Humax.
Have tried reinstalling without any joy - I`d understand it better if it just didn`t work at all, but to work a little bit but not well - don`t understand. ??knackered card.
pc::
ckrys1 is offline   Reply With Quote
Old 15-08-2003   #2
w hole's Avatar
Hello Ckrys
Sounds like it might be an LNB problem.
Do you use more than one?
Regards
W. Hole
w hole is offline   Reply With Quote
Old 15-08-2003   #3
No just 1,a syntec dual output. 1 output goes straight to Skystar, but if I put this cable into my Humax, all channels are receivable,so that made me think it wasn`t a dish/lnb/cable problem
pc::
Old 15-08-2003   #4
rolfw's Avatar
Real name: Rolf
Can't think of any software reason that the card would be offering reduced performance Ckrys1, unless any of the LNB parameters have become corrupted. If the LO frequencies were slightly out, this could affect signal strength and quality.
Rolf
Old 15-08-2003   #5
Thanks Rolf - the LOF`s were set on the Skystar software at 9750 and 10600 with a switch at 11700 - would that be ok for universal lnb?(syntec 2000)
pc::
Old 15-08-2003   #6
rolfw's Avatar
Real name: Rolf
Should be Ok, as I say, haven't any idea otherwise what may be the problem.
I'm presuming that you've checked whether the problem exists on all LNB states, ie, H,Low, V,Low, H,High and V,High.
Rolf
Old 15-08-2003   #7
Ckrys1,
skystar card could be locked by software. check this http://forums.dvbnetwork.com/ for unlocking skystar PCI card.
radiotech is offline   Reply With Quote
Old 15-08-2003   #8
rolfw's Avatar
Real name: Rolf
That should only happen with the EOL cards though Radiotech, although it is of course worth checking.
Rolf
Old 15-08-2003   #9
Yep checked that and the only pattern is that ALL signals are drastically reduced, equally so the only channels I`m left with are ones wiyh huge signals to start with. As you say it must be a signal problem and I should have said the problem only started after I`d fiddled with the elevation of my dish, BUT didn`t think this was relevant initially `cos the alteration has improved the signal to my other receiver. Why it should improve the signal to a Humax and decrease it to a Skystar card defeats me, but I`m beginning to think another twiddle with the LNB/dish might be neccessary- have to wait till the wife`s not looking of course!
pc::
Old 31-10-2003   #10
amdaley28's Avatar
Hello Everyone.
I have just read through this post & heres my penny worth.
The lnb you are using.Is it a twin output or dual output?
The reason I ask is because one has 2 seperate outputs & the other has 2 of the same.If it is 2 of the same the Humax may be contrilling the lnb.Try switching off or removing the Humax when you are using the Skystar.I have found that if you have 2 receivers connected to the same lnb one of them wont show any signal.
Regards.
amdaley28
"No just 1,a syntec dual output. 1 output goes straight to Skystar, but if I put this cable into my Humax, all channels are receivable,so that made me think it wasn`t a dish/lnb/cable problem"
Regards.
amdaley.
amdaley28 is offline   Reply With Quote
Old 31-10-2003   #11
rolfw's Avatar
Real name: Rolf
It would be interesting to know how ckrys1 got on with the problem, I think that the LNB was a twin, so should be no problem with the other receiver and as he said, he'd tried both sides of the LNb with both receivers.
Rolf
Old 31-10-2003   #12
amdaley28's Avatar
Hello rolfw.
It did work,he changed nothing.I think if the lnb is a twin output & not a dual output,it must be a hardware fault with the card.I hope he tells us how he got on.
Regards.
amdaley28
Regards.
amdaley.
properly, skystar, working
Similar Threads
Topfield PVR 4000 is not working properly with irdeto! why? GroupWar Receiver software, international Section 5 15-10-2004 07:29 PM
I need working emulator for c***x!!!!!!!!! Peak Conax, Cryptoworks, Nagravision, NDS and Others 1 17-02-2004 04:51 AM
Best video qualtity, Skystar 1 or 2? mtiller Satellite PC Card Receivers & Internet by Satellite 13 03-12-2003 09:30 PM
Asianet is not working with some recievers (eg. Palcom DSL-2100 CI, SLV 18 D CI) just29 Transponders & channels 6 27-11-2003 01:15 PM
MSN hotmail on WAP not working Shahid Mobile phone/GSM chat 0 24-08-2003 06:27 PM
