SS2 card Jumper setting ?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 22-08-2003
| Hi All.. I'm just wondering what the 2 pin jumper is for on my card?. The manaul does not mention it at all, i did a search on some forums but it never seems to have been mentioned. Strange really the only software i can get to work properly is MyTheatre but it seems good so far. Progdvb says card not started even though i have the correct skynet.sys. DVBViewer has the dreaded #90010115 error !. Can't get DiSeQc to work.., SS2 Init error. Anyway i should not complain if it's working...hi thanks Rob | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just had a look at my card bobit, couldn't see a jumper, is yours the latest revision? | ||
| @rolfw Yes this is a fairly new revision i think, it says 2.68 on the card. The jumper is to the bottom right of the tuner next to the main B2C2 IC. I have tried changing the jumper over but it does not seem to make any difference. i thought it could be hardware irq setting or something, but it is a plug n play card... who knows what it's for! Rob | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That would explain it then, could be worth going onto the www.technisat.de site and using the contact button to ask them. | ||
| | #5 | ||
| Regular Member Join Date: 02-11-2004 Location: DUblin
| Hi Bobit, It is mentioned in the pdf files on the CD that if you install the card and if in "Device Manager" the card shows up with a yellow ! mark you change the jumper to shorting the 2 pins. But I have no idea what it does Maurice | ||
| | #6 | ||
| Regular Member Join Date: 04-09-2004
| hello, The rev of the skystar2 card with jumper is called as 2.6B not 2.68.The jumper is used if BIOS is not identified the card.The jumper is used only for older non PCI complaint motherboards. | ||
| The Following User Says Thank You to nacturnal For This Useful Post: | Frozen (19-06-2009) |
| card, jumper, setting, ss2 |
Similar Threads | ||||
| Irdeto debuts CA module with embedded smart card | net1 | Irdeto system | 0 | 04-02-2004 07:50 PM |
| Which DVB card? | alnitak | Satellite PC Card Receivers & Internet by Satellite | 4 | 26-08-2003 02:17 PM |
| Pentamedia card not initializing | s*t*a*r*m*a*n | Computer Discussion | 1 | 14-07-2003 05:07 AM |
| new card don't work | Robbiewright | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 25-06-2003 09:05 PM |
| SS2 and DXR2 | refinechange | Satellite PC Card Receivers & Internet by Satellite | 0 | 23-06-2003 01:43 PM |
