Crash on exit from ProgDVB
Old 21-09-2006   #1
My System: Arion AF-8500MCI, 1.2m dish, USALS H-H, 2db dual output LNB, SkyStar2
I'm using the latest version of ProgDVB 4.78.6, but the problem has been the same for some time and previous versions now - since before prog issued a release to fix the "crash on exit" problem.
When I exit ProgDVB, I get the following message;
The instruction at "0x04012230" referenced memory at "0x00000000". The memory could not be "read".
It doesn't seem to cause any great problem, just means I have to click two more buttons, but does anyone know what cause it or how to fix it? I searched the forums and googled, but nothing. I don't think it's hardware related because I just bought a completely new PC and installed from scratch with exactly the same problem...
Raasay is offline   Reply With Quote
Old 21-09-2006   #2
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
Try loading 4.62.6 into a different directory (c:\program files\progdvb) and see what that does.
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 21-09-2006   #3
Thanks Lancelot, I'll give it a try tonight and let you know...
Old 09-11-2006   #4
In the end I had to go back to 4.56.2 (last pre-ProgDvbEngine version). I don't know what I'm missing using the old version, any ideas? I know already that channel lists from newer versions don't work so I had to rescan every satellite
crash, exit, progdvb
