DVB Video Capture?
Old 28-11-2003   #1
My System: Innovative, Diseqc Motor, 80cm dish
DVB Video Capture?
Hi All
A bit of a stab in the dark this, but anyway...
I have just bought an NEC DVD+RW drive which came with nerovision dvd authoring software.
When i capture video from my skystar2 using progdvb and try to import into nerovision, it reports that this is not a standard mpeg2 stream.
Now i obviously dont when to spend hours transcoding etc, is there any other better/flexible capture sofware available for the skystar2. I think the main downfall being i am tryin to record an encrypted video stream.
Any Ideas?
cheers
FILE INFO
File: 2.32 GB (965 MB), duration: 1:55:28, type: MPG, 1 audio stream(s), quality: 76 %
Video: 859 MB, 6000 Kbps, 25.0 fps, 720*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD)
Audio: 105 MB, 128 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0]
homerjay is offline   Reply With Quote
capture, dvb, video
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
Video Capture Cards malcolm Computer Discussion 6 25-02-2005 12:30 PM
SKy+ installed but now I have a video problem? rapterman Sky+ (Plus) and PVR Systems 3 03-02-2004 08:42 PM
Free premiership video clips from '3' net1 Mobile phone/GSM chat 0 14-08-2003 07:40 PM
