USB Skystar2 problem
Old 06-10-2006   #1
My System: fte 420;dreambox 500-s;Dreambox-7020si;DM 800 HD;skystar2 usb+usb2;fte max-100;antenas fixas Hisp,Nilesat,Atlant bird5 W,Hotb,Astra1,2 e Eurobird
Hi
Can anyone help with this?I have a Usb SStar2 which has been working with Progdvb and vplug on a Toshiba Sat pro M30 with no problem.Recently i got a Toshiba Tecra M5 and when i tried the same combination i succsessfully installed it and all was well for about 5 mn...then i received a blue screen with warnings that newly installed hardware was not compatible...i tried a second time with a fresh instalation but it happened again.I used the last 4.4.0 driver from technisat and vpug 1.3.1....Any sugestion please?
THX
sebastiao vivo is offline   Reply With Quote
Old 08-10-2006   #2
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
i might be wrong but...
i seem to remember aikon (mike) had trouble with 4.4.0 driver and he rolled it back to 4.3 or earlier and that did the trick
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 12-10-2006   #3
aikon0029's Avatar
My System: CPU IntelŪ PentiumŪ 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1.1mtr steerable dish Manhattan XT[CM, Quali 1080ir
Sorry M8 did not see the posting until today, otherwise I would have answered him. Do we know if he did try that, as he did not reply to you.
aikon0029 is offline   Reply With Quote
problem, skystar2, usb
