Connecting my motorised system to laptopDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 10-05-2006 Location: notts uk
My System: sky + TM 1500CI 31.5W - 39E |
Hi I'm wanting some advice please, basically I have a tm1500 motorised system, I want to be able to control the dish via the TM but be also able to view the pics on my laptop. This is all so I can view 4.2.2 feeds, the connector needs to be usb with it going into a laptop, I assume this will be easier than to keep changing cables to control the dish via the tm and then via the computer.Any help advice links products ideas much appreciated. Thanks. | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | to view 4:2:2 feeds you will need a usb sat card the laptop just wont decode a signal from the reciever to the laptop | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | This is really the wrong section to ask the question, as you are asking about PC based satellite receivers. Will move it to the Satellite by PC section. There are probably a lot less people than you'd think using laptops for satellite reception, but I would imagine that the Skystar USB will do 4.2.2, as the PCI version does. | ||
| connecting, laptop, motorised |
