how happy are you ?
Old 20-11-2006   #1
Talking how happy are you ?
just a thought
how happy are you with your pc based sat system.
does it live up to your demands .
does it make you feel all warm when the closed channels are opened up.
is there anything else you would like to do with you system.
what could/would add to make it better for you.
and what spec is your pc you use to run it on.
im happy with my skystar set up. it does everyting the high end rx units...
id love to see more hd channels
i would love to see a twin tuner version .
the spec of my media center pc is as follows..
amd athlon 3200 64bit 1 gig of pc3200 sound blaster live 7.1
800 gig of storage, nvidea 6200, dual layer dvd rw
20inch hd tv hooked up via dvi on my videocard.
i now have 3 dishes the usal hotbird astra useing a 90cm dish and mono block 60cm on hipsat and a 45cm on the astra cluster at 28deg...
i would love to have a setup for feed hunting and alike..
regards andy ..
andysly is offline   Reply With Quote
Old 21-11-2006   #2
gromit4x4's Avatar
My System: HTPC: AMD Athlon 4200+ X2 | Twinhan sat CI DVB-S | Nebula DVB-T | iMON rsc | HD70 | Kenwood DVT7000 | Tannoy EFX5.1 | Moteck SG2100A | ISS 80cm
Very happy, I could do with a bit more processing power to cope with the HD stuff but otherwise it suits my needs exactly, plays dvd, does sat tv and moves my motor on channel change, freeview and topuptv and serves all my digital media
I'm using:
XP 2200+
512mb 3200
300Gb SATA
Nvidia 6600gt
Twinhan 1030 dvbs with progdvb
Moteck sg2100
Nebula dvbt with digitv HD
5.1 audio via spdif and an av amp
all in a Thermaltake tenor case
controled by an iMON rsc remote and a wirless keyboard
Image is provided by a Themescene HD70, image is 81 inches diagonal (makes for some interesting viewing)
gromit4x4 is offline   Reply With Quote
Old 21-11-2006   #3
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Does a skystar I decode HD? If it does I could put one in my HTPC and watch it though my projector Then I'd be happy
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 25-11-2006   #4
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
well it definetly wouldn't do it on HW but i think it can do it on software, like a skystar 2 (but then again, it's not the card itself that decodes it, it's the cpu+gpu if any acceleration enabled innit?). I reckon there's some threads about that on dvbn...
btw, when talking about HDTV by all means try to precise, as there's mpeg2 and mpeg4/AVC/H.264 which is a totally different ball game m8
oh and yeah, it obviously doesn't do any dvb-s2 which unfortunatly tends to go along HD these days
kamaleon is offline   Reply With Quote
Old 25-11-2006   #5
kamaleon's Avatar
I'm on the process of renewing my setup into core 2 duo, and 2x skystar 2 so i'll get back to this thread to say how happy i will be then - hopefully VERY VERY happy
Old 09-12-2006   #6
DVB-slut's Avatar
My System: Fortec Star Dynamic Decoder 90cm Dish USALS Motor SkyStar2 PCI PROG DVB DVB VIEWER
I would be a hell of a lot happier if there where some D+ keys out there that actually worked. Does anyone remember working D+ keys? Those where the days….
DVB-slut is offline   Reply With Quote
Old 09-12-2006   #7
mhku's Avatar
I meant skystar 2- software decoding of hidef needs a hefty machine.
Does skystar 2 decode hidef (using hardware rather than software)? BY hidef I mean BBC HD and similar stuff. I've tried decoding a hidef film using coreAVC and it was unwatchable- killed the machine- and coreAVC is supposed to be the best...
Old 13-12-2006   #8
kamaleon's Avatar
Mine certainly does now :E6600 on asus P5B deluxe, 2GB ram teamgroup xtreem, 6600GT gpu
i think your getting the hw/sw terms a bit mingled though
happy
