tsreader liteDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 24-11-2005 Location: uk
My System: 1.8 motorised Channel Master Quali tv+ Manhattan 500 |
Hi, I have a skystar 2 card and want to use tsreader lite to record the .ts files of a feed I want to record the ts file so i can bruteforce some keys. Could any one help with the tsreaderlite set up. Screenshots would a real help. If there is a simpler way tp record .ts file I am always eager to learn. Regards | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | AFAIK, don't think you can with the lite version. Llew | ||
| Regular Member Join Date: 02-12-2005 Location: str8 frum da wesside innit?
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s... | Altdvb can do it. Can you pleeeaazee come back later and tell if your bruteforce attack worked? ![]() ![]() | ||
My System: 1.8 motorised Channel Master Quali tv+ Manhattan 500 | Hi Kameleon, I will gladly keep you informed of any progress. Thanks for the advice. Alt Dvb will be the next program i try. Where can i get some instructions for alt dvb. I found problems getting a signal. Whats the best codecs and filters also plugins to use with it. Mike | ||
| lite, tsreader |
