Please help with progdvb and emuDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 12-01-2004
Hi! Please help me to set up progdvb to work with all the channel in sirus 2,3 5E Its no prblem to run progdvb but i don understand how or wich software to use and how too insall it in right plases? I have downloade mdyakse 109, fun2md. Is this the rigth file? and how to install it? Please note step by step I run skystar2 pci card.Regards Rune. | ||
| Big Hairy Bugger Join Date: 13-01-2003
| Go to www.progdvb.com and download progdvb software including plugins for wintv nova if you have that card and dixie for motor system. Download latest Yankse (has conax keys built in)and from http://yankse.dvbnetwork.com/ Install progdvb Extract yankse into same directory as progdvb.exe Download latest Shadows with softcam and extract softcam to same directory as progdvb.exe (search upload sites) Go to http://www.dxandy.de/cgi-bin/dvbchan.pl and select which satellites you want and create a channels file to import using BinaryDVBEdit choice or scan satellite Import channels Transponders for scaning can be updated with info from http://joshyfun.webzdarma.cz/transponders/ Start progdvb if you see nothing make sure you have the right card selected and also select a free to air channel. Now select pugins and under Yankse select Active, Auto Pids and Auto ECM and Read PMT on sid change. For snitch on nagra you can leave it on find keys with very little CPU used. Now select a channel that is scrambled and viewable with 6 in 1 and you should be able to view channel. | ||
| emu, progdvb |
