newbie optus b New Zealand Help (please)Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 15-01-2004 Location: Manukau New Zealand
I have a telemann skymedia200 card (SkyMedia200.html" target="_blank">http://www.telemann.com/products/SkyMedia200.html) in my Comp (533mhz intel, 256 mb ram). a 90cm dish looking at optus b from Auckland New Zealand. I got all the frequencys from Lyngsat.com. (I also have a telemann sm200dpa/n card (SkyMedia200D.html" target="_blank">http://www.telemann.com/products/SkyMedia200D.html) in the cupboard if needed) the telemann software works well on the uncrypted chanels (good pics and audio) good lock test, and ch. scan finds all the stations. but the channels I'm interested in (abc & ch 10 from Australia ) are encoded using irdeto and dvb ??. All I get on them is a blank screen and no audio I'm not interested in Sky ( crypted in videoguard). I've downloaded mutlidec and freedvb but neither of them will aknowledge my sat card I'm pretty green at all this (but trying hard to understand) Soooo what am i doing wrong any Ideas also what do pids and cams do and what is yankse ?????? Rincewind from the antipodes | ||
| Big Hairy Bugger Join Date: 13-01-2003
| m8 I think that card is not supported. http://www.progdvb.com/ has plugin for teleman 300 only. you could try that plugin and see. | ||
| | #3 | |||
the patch for sm300 does work for sm200. like i said it works fine on uncrypted channels (thanks to rust (-: ) my problem is decrypting irdeto 1 any suggestions? rincewind | |||
| Member Join Date: 01-01-2000 Location: Downunder
My System: 3.6M Ku Band Orbitron, 3.0M Orbitron C band. 1.2M Ku offset, 1.0M Ku Offset, 90Cm/Moteck Ku, 65Cm Ku Offset, 1.2m Paraclips Hydro C Band Nokia Dbox 9500s, Nokia Dbox2, 2x Dreambox 7020s, Dreambox Dm500s, 2 x Dreambox Dm800 HD, UEC 660, Pace HDi PVR | Hi rincewind.. I'm in New Zealand too.. Just a quik pointer.. you wont be able to receive Ch 7 9 and 10 off any of the Optus b1 B3 or C3 Sats.. Not with your 90Cm anyway.. If you take a look at lyngsats site you see that those Channels are directed at Aussie and are on the Horizontal pol.. As you'll probably have noticed, no Horizontal Signals are available here in Nz.. Only Verticle signals only.. I have managed myself to lock onto Horizontal Signals off C1 (Foxtel) using a 3M Dish.. even then the signal level was only just over threshold of 40%. As far as getting keys for those services.. you'll probably find it quite tough. Foxtell/Austar have just gone over to Irdeto 2 and NDS encryption. so that prtty much shuts you down for any decrypting etc.. Aurora however is still using Irdeto 1 and 2.. so you still have the choice of that.. Both Aurora packages are currently available from Optus B3 and C1.. Keys can be found for this service, if you talk to the right person. Cheers : Hope that helps | ||
| pc:: | |||
| | #5 | ||
| Member Join Date: 17-06-2004
| Hey Guys, Im also located in newzealand havn't got any thig as yet but wish to know best stuff to by for receiving optus 2 and decoding sky and anthing else thats in english any help including where i can pick up decent inexpesive decoders etc and best cam/smartcard to use in my area would be appriciated.Cheers | ||
| | #6 | ||
| Guest
Posts: n/a
| If the Telemann software dont use regular plugins then it will not decrypt anything. You are best to buy a different card that will run the right software,and if you dont plan on upgrading the computer too ,then your choice should be a Nexus-S as it seems to run fine on anything I have tried it on. I recomend MyTheatre 2.76 and MAYBE the newest version of ProgDVB for software. I think MyTheatre 2.76 is the easiest and most stable ever released for DVB cards, I use it and highly recomend it.Plus its FREE ! | ||
| | #7 | |||
| | #8 | ||
| Member Join Date: 15-07-2004
| Hi there hating to sound real dumb and all but im looking for some answers to some qestions...mainly is it actually possible to decode new zealands digital sky? and what sort of price range are we talking and what sort of quality do we get? oh and is that the big ted i know form gaggles? | ||
| | #9 | ||
My System: 3.6M Ku Band Orbitron, 3.0M Orbitron C band. 1.2M Ku offset, 1.0M Ku Offset, 90Cm/Moteck Ku, 65Cm Ku Offset, 1.2m Paraclips Hydro C Band Nokia Dbox 9500s, Nokia Dbox2, 2x Dreambox 7020s, Dreambox Dm500s, 2 x Dreambox Dm800 HD, UEC 660, Pace HDi PVR | Hi there Spawn.. In reply to your question.. No.. At this stage Sky Digital to my knowledge and understanding has not been compromised. If you do a search via pretty much most forrums you will get the general idea that NDS (Sky Digitals Encryption) is currently very secure. Your best bet would be to Watch Sky Via Tv tuner card off the UHF Service using HVC.. Cheers: | ||
| pc:: | |||
| | #11 | ||
| Member Join Date: 10-08-2004
| spawn, I saw something of interest for vide*guard and ir*eto 1 and 2. Take a look at this web site and please keep me inform if you see anything of interest. I'm moving to Brisbane in a few week and I just bought a Nexus-s DVB card. I'd be please to know if there something out there who would be useful againt Sk*TV and its POD encryption scheme(Video*uard). http://www.lefdata.com/satellite/cam/ci.html | ||
| newbie, optus, zealand |
Similar Threads | ||||
| newbie help prog titanium | bobo63 | Cards & Programmers General | 6 | 02-03-2008 08:23 PM |
| newbie newbie | saxfoon | Digital systems | 1 | 18-01-2004 08:32 PM |
| newbie diseq motor help | pluto | Satellite PC Card Receivers & Internet by Satellite | 2 | 28-08-2003 11:25 AM |
| Newbie needs help with Sky | Skullface | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 26-08-2003 06:21 PM |
| newbie newbie | pluto | Satellite PC Card Receivers & Internet by Satellite | 1 | 26-06-2003 01:49 PM |
