Not recieveng SIGNAL?!? help?
Old 30-12-2006   #1
My System: ss1
hi
i have skystar1 card with motor dish, for the last two years its been fine, i updated my comuter and forgot i even had the dish untill last week, so it hasnt been unsed in a while, i instaled the skystar drivers and ran the progDVB program i used too used, last year, but i cant get a signal when click on the channels,
i usually click on plugins/dixie/parametres to move the dish to a new sat, but i dont think thats working either,
how would i find out if there is communication between my pc andthe dish?
and how can i fix this?
cheers,
Ryan
cdnw06015 is offline   Reply With Quote
Old 30-12-2006   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Have you checked the LNB settings? Click on the Diseqc button in Progdvb, they may need reconfiguring.
Llew is offline   Reply With Quote
Old 31-12-2006   #3
My System: ss1
lnb settings
in the sat position ad diseqc settings, what shoud it be set to?
there i little green ball set on hotbird but when i open this i get the option to change it to all the other sat positions,
on the left ive got diseqc; none , mini-diseqc, 1.0 or 2.0, and custom, which one shoud i check?
at the bottom ive can choose distinguish; frequency or LNB
what should that be on?
cheers
recieveng, signal
