progdvb & ac3
Old 07-01-2007   #1
yuriythebest's Avatar
My System: pentium 4 3.06ghz with ht, 1 gb ram, ss2, 1.15m motor dish, strong srtv50
progdvb & ac3
I'm trying to switch to ac3 (original) mtv audio (mtv polska), however it freezes. My setting is: tv with ac3:Elecard + valex ac3. whatdoIdo?
yuriythebest is offline   Reply With Quote
Old 08-01-2007   #2
advice? anyone?
Old 08-01-2007   #3
Amo Amas Amant Admin
Topper's Avatar
Mmm
Originally Posted by yuriythebest View Post
advice? anyone?
Well my advice is simple try to describe exactly what you are doing as your original post looks like a load of secret code to me and does not even make an intelligable sentence. It may do to someone who also talks this kind of geek speak but we expect people to speak English on here
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 08-01-2007   #4
My System: Skystar 2, (so far) Hopefully 80cm dish & 0.3db monoblock P4 2.53Ghz O/C 3.02Ghz Athlon XP 2200 HTPC Barco Data 701 CRT Projector 87" wide 16:9 screen
Hi there
AC3 through progdvb is easy using the elecard/cyberlink/nvidia/intervideo codecs, its as simple as ticking the SPDIF output in 'file', 'property' 'audio settings'.
In Valex's AC3 filter, on my system, if i check the SPDIF out in the AC3 filter control panel it hoses all my video playing software and like you say crashes your computer.
You are best off using the audio decoder in the Elecard codec, or one of the others nvidia etc, but id stay away from AC3 filter.
hope this helps
JAmes
PsychoDogBeast is offline   Reply With Quote
Old 09-03-2008   #5
My System: PROGDVB
merci sympa
djamal is offline   Reply With Quote
ac3, progdvb
