Shaking Video in progDVB :(Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Crazy Techie Join Date: 28-04-2006 Location: Maharastra, Hindustan
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish |
Hi Friends I'm experiencing a little shaking video in progDVB 4.81 with my SS2 v2.6D with 4.40 driver. plz see the running text in the lower part of the attached snapshot. You can see the video is shaking there when the video changes. Any solution to that ? | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Try using a different video codec. Cyberlink (new) seems quite good, also use the Intervideo audio codec, then see which video renderer works best. | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Try To switch to other Codecs, There are many Codecs, Try to install and Switch, and what is your CPU Usage, can you pls define. | ||
| | #5 | ||
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Install Cyberlink PowerDVB 7 and the codec should install. | ||
| progdvb, shaking, video |
