Help Needed Re Pinnacle PCTV Sat Pro PCI
Old 25-01-2007   #1
andi968's Avatar
My System: Sky Plus PCTV Sat Pro PCI 3.4 Ghz
Hello there everyone
I am a new member to this site and was pointed this direction by Sky themselves I called them to see if they sold a PC based card reader so I could use my sky card with my PC to recieve the channels I subcribe to.
My problem is I have a Pinnacle Sat Pro pci card I have tried using most of the software available but come unstuck when trying to enter in the cam keys. Is there anyone out there who would be so kind as to take me through the proceedure step by step also tell me the best software to use
Many thanks in advance
Andi
andi968 is offline   Reply With Quote
Old 25-01-2007   #2
Site administrator
Analoguesat's Avatar
Sky have punted you over here as they do not know what to do with awkward questions!
Sky do not sell any PCI based cards, and there are no official NDS cams available..
IF the pci card has a cam slot on it you may be able to use a dragon cam in it. If not you cant do what you are trying to do.
Analogue forever!
Old 25-01-2007   #3
andi968's Avatar
Thank you for the info no its just a bog standard sat pro
Old 25-01-2007   #4
Site administrator
If its this one:
http://www.cd-writer.com/catalog/pinnacle-pctv-p-8367.html
then you get to watch the fta clear channels on 28E only. Theres absolutely no way to watch the sky pay channels on it.
Analogue forever!
Old 25-01-2007   #5
andi968's Avatar
Yes thats the one..But without moving the dish it picks up from hotbird as well as a couple of others within 10 degrees either side of 28.2 all told it has picked up around 910 fta viewable channels which has supprised me to say the least.
Once again Thank you for your help
Old 25-01-2007   #6
Site administrator
Unlikely - Hotbird Astra 1 and Astra 2 all use the same frequencies, so if you scan certain frequencies on one it appears you have got channels on the second and third slots as well. A satellite dish typically has an acceptance angle of around 3-4 degrees
If you have the English stuff on 28E, the Italians on 13E and the others without moving your dish you have some pretty freaky signal reflections in your area!
Analogue forever!
Old 25-01-2007   #7
andi968's Avatar
Not got a signal on 13E .
Old 25-01-2007   #8
Site administrator
Little is impossible in the world of sat reception, but some of it is pretty improbable.
Analogue forever!
Old 25-01-2007   #9
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Re-radiating power from those birds to your dish from that mast would be several watts short of a miracle
Llew is offline   Reply With Quote
Old 30-01-2007   #10
aikon0029's Avatar
My System: CPU IntelŪ PentiumŪ 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1.1mtr steerable dish Manhattan XT[CM, Quali 1080ir
Andi
Hi this is probably a negative as you can get, but that card was tested on Dr Dish a couple of weeks ago, and they probably have more equipment to test than any of us on here. They slated the software in trying to get it to work, but they did contact Pinnacle for help. They then tried it again with the info Pinnacle had supplied them and still it would not work. This happened twice, and in the end they gave up, they then took it outside and said it was not worth all the agro, and the best place for it was in the trash bin, and thats where they put it. I was going to try one, but having seen the report I decided to keep my money. But then again they could be completely wrong. I do hope you are able to get it working, and that this post is not too dissappointing.
aikon0029 is offline   Reply With Quote
needed, pci, pctv, pinnacle, pro, sat
