TPS Star H.264, M6 H.264, Premier HD.Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 12-02-2006 Location: Ireland
My System: Microsoft Media Center, Intel Core 2 Duo, 1 Gig DDR2 800, NVidia 7950 GTX with component out) JVC 36" Widescreen TV with component in. 70cm Motorized Dish and sat receiver. |
Hi all, I have a pc with a skystar 2 card. I can get BBC HD just fine using DVB vewier pro and the CyberLink Codecs, works a treat. I can't lift TPS Star or M6. I'm using vplug and M6 seems to be ok but not TPS Star, I have an invalid key error. No joy at all with Premier HD. Anybody got any pointers. Thanks | ||
| Folding*home Join Date: 23-02-2006 Location: Madeira
My System: [ Relook 250S ] | What about coreavc, does it work with you? Besides that you should know that you can only receive DVB-S with a SS2. | ||
![]() When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork." | |||
My System: Microsoft Media Center, Intel Core 2 Duo, 1 Gig DDR2 800, NVidia 7950 GTX with component out) JVC 36" Widescreen TV with component in. 70cm Motorized Dish and sat receiver. | Hi, thanks for the update. I can see what your saying about the DVB-S with SS2. I'm running Microsoft Media center on my pc and I'm using DVBViewer. I use DVBViewer because I can run it with the remote. Vplug 1.5.8 seems a little unstable lately. I don't know if its because of my reception. I can't find Premier HD on a scan. I find the Cyberlink HD264 drivers works well. I don't like the Corevac it seems unstable for me. Could you recommend a good DVB-S card with SS2. Thanks | ||
My System: [ Relook 250S ] | Whell I find that Altdvb is a better choice for weaker signals, perhaps you should give it a go just to check if its a sat viewer snag. As for the remote, you can use the SS2 (skystar2) remote using winlirc, but it can be a pain to setup correctly, I quit trying... Vplug is ok most of the time, but I too am getting problems with it on altdvb, but on dreamdvb it works a lot better, seems a tiny bit faster to change and "open" channels aswell. I suppose you are refering to a DVB-S2 aka HD card on your last sentence... I have no experience with them so i won't go into it. But one thing I know, for one of those DVB-S2 cards to work correctly you need a powerful pc with a nice graphics card to help demux h.264. Requirements for HDTV [1080i / MPEG 4 (AVC/H.264)] - 3,4 GHz P4 (Single Core with hyperthreading) or - 2,2 GHz AMD 3500 + or - Dual Core P4 D820 / D830 or - Dual Core AMD X2 3800+ - with graphics card: ATI X1600 / X1800 er NVidia 6600 GT / 7600 GT Tecnisat has a DVB-S2 card, if I get one it might be one of those. http://www.technisat.com/?site=produkte/produkteview.php&kid=29,100&pid=1747&reload Other brands have it as well and they seem to be pretty much the same hardware just a different badge, but i still have to check that a bit more. http://shop.technotrend.de/shop.php?mode=show_detail&lang=de&group=3&id=42&si d=83f60a74aa6445fcf00c292cb65982fa | ||
| | #5 | ||
| Specialist Contributor Join Date: 21-08-2004 Location: Wales
My System: Technomate 1500CI+ and Hauppauge WinTV NOVA-HD-S2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish. | Well M6 and TPS Star HD are encrypted in Viacess 2.5 anyway. You are probably decoding M6 SD. AND Premier HD is in DVB-S2 so no chance what so ever with a skystar 2. | ||
| | #6 | ||
My System: Microsoft Media Center, Intel Core 2 Duo, 1 Gig DDR2 800, NVidia 7950 GTX with component out) JVC 36" Widescreen TV with component in. 70cm Motorized Dish and sat receiver. | Thanks for the info guys. I got my stability problems sorted by reading the help for DVBvewier. I have a dual core system and I flicked off the option to use the first processor. DVBVewier becomes unstable if you are using a SkyStar2 card. DVBVewier is now running rock solid. I like the DVBVewier because I can use my media center remote with it and the user interface is very good. I downloaded the dll for the remote from the DVBVewier forums site. My BBC HD is pretty good and my system runs at around 35-55%. Its still a tiny bit gerky and have the feeling that its not the system but the skystar2 card. I think i'm going to upgrade to the technotrend card S2-3200. Thanks for all the help. | ||
| h264, premier, star, tps |
