skystar2 no signalDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 14-06-2007 Location: canada
My System: progDVB skysat2 |
Hi admin, hi everyone, I have try your softwareProgDVB but not working. problem: i have no signal at all. pc: i have a P4. enough DDR memory. XP pro with pack 2. i have skystar2 installed with latest drivers. i have dish that works in my stand alone receiver. hotbird+astra. i plugged only hotbird cable to my card. so no DISEcQ. Here what i've done: I tried to setup both. progDVB and setup4pc. setup4pc is red. no signal. i tried to scan channels but no channel at all (wich is normal coz no signal) Here are printscreens of my settings. please help me coz its so exciting to have a dish+pc sat card and very frustrating not being able to use it at all. (i tried to search in forums and now..im just disasperate..) | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Hi dolphyn, welcome to the forum. You're in Canada, and trying to receive Hotbird and Astra? No chance. BTW, Pic3, ProgDVB LNB settings for LOF1 should be 9750. Llew | ||
My System: progDVB skysat2 | oups! sorry i forgot to mention that im right now based in tunisia! and yes im canadian![]() as mentioned earlier, i already have a dish and can watch hotbird and astra only uncrypted channels on my tv.. Thx for the suggestion. I have changed the settings as u mentioned it. still not working..:/ im patient..i keep waiting more suggestions | ||
I understand there is not a lot open on Hotbird at the moment | ||
| | #6 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Don't use Setup4pc, just use ProgDVB and as I said, put in your correct LOF1 frequency. | ||
| | #7 | ||
My System: progDVB skysat2 | 1.should i uninstall setup4pc or just shutting it down? 2.just LOF1=9750 that's all? sry for not testing right away before asking...coz cable plugged on tv is pretty far from pc..and i need to move pc near tv to check..wich is not very convenient..:/ but im gonna give a try and be back to forum to let u know. Thx for helping. I really appreciate! | ||
| | #8 | ||
My System: progDVB skysat2 | ok i done it. no success. I shutdown my av kaspersky (just in case..) i shut down setup4pc. i scanned channels. nothing found. i scanned transponders. nothing. no signal. beats me..dunno what else i could do..:/ | ||
| | #9 | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Is Your DVB Card waking up, If not then kick start your card. Then i am sure that u can add DISEcQ and later thinks, Progdvb has some problem few times to wake cards, ths why it wont work. | ||
| | #13 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Check your Pm dolphyn, Submit your driver version. | ||
| | #14 | ||
| Member Join Date: 09-02-2008 Location: Romania
My System: strong srt6125 offset 1.1m | hi . i have the same problem. no signal on skystar2 pci with altdvb. i install de newest driver for skystar2 card and it is work perfect with progdvb but no signal with altdvb on thor 2,3. it is posible the altdvb can not start the skystar2 card??? the same altvb software work perfect on skystar2 at my frend. he can watch al the chanels on thor2,3 . the altdvb software is better then progdvb and i am angry becouse d'ont work on my pc (intel core 2 duo e6750 at 2660 mhz, 4 gb ram on the abit ab9 matherboard and 9600 gt vga card. sorry for my dab english. thank you for try to help me. by ps: i try 5 or 6 wersions of altdvb and no signal at all. any version of progbvd work well. | ||
| signal, skystar2 |
