S*y on PC | |
| Member Join Date: 28-08-2007 Location: UK
My System: AMD 64 3200+ 2.00 GHz 1 gb ram pci dvb-s nova |
I have a question regarding receiving s*y on my pc I have a setup that can take a cam and asume that iam capable of getting it to work with correct cam, firmware etc.. Now when i have everything running with my viewing card in is it possible to remove card and carry on receiving picture? So card can go back in the box in living room. Cheers M0nster | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, I don't know for certain, buy I'm pretty sure taht as soon as you whip the card out the picture will go, that is what happens on my Sky box. What CAM are you intending to use? | ||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Remove the card and lose the picture. There are no freebies with Sky!
__________________ | |||
| | #5 | ||
| Member Join Date: 21-11-2006 Location: Northwest
My System: Nokia 9600S (NDT tuner) linked via RS232 to Echostar LT8700. Motorized 1.2m Echostar offset dish on polar mount with 12" 36V jack. Combined Ku feedhorn polarotor with Calamp WR75 0.8dBN quadband LNB. Skystar2 v2.3 via splitter. | You could use those wireless cams in a couple of non-sky boxes and thus receive 2 different channels at once from 1 card, a bit like sky+ does, or does that not work any more? | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you are referring to the SmartWi, then it doesn't work with Videoguard.
| | #7 | ||
| Member Join Date: 29-04-2006 Location: London
My System: 2.4m Precision Prime Focus Dish. Dream 7020, V-Box II Asus P5K E6570 (twin 2.66meg) CPU 2gig ram Technisat Skystar2HD DVBViewer, CoreAVC, WinDVD9, PowerDVD8 Nebula DTT, 3.7.11 |
I've been doing a lot of reading lately and I have seen on another forum (but can't remember which one) that a chap has done successfully what you were askin. | ||
