Offline Download??? | |
| | #2 | |||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | We had a similar request last week from your location. The bottom line is that you need to subscribe to an internet service provider like Europe on line and need a local ISP. If websites are blocked in your area, then this might not be of much use. Which websites are blocked in your location? What kind of data are you looking for? Here is the link for the other request: DvB pci card?? | |||
| The Following User Says Thank You to HB13DISH For This Useful Post: | Milad_ran (01-06-2008) |
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | I am still not with you. Why do you need satellite internet for download instead of the usual dl through your ISP? | ||
| | #5 | ||
| Member Join Date: 27-05-2007 Location: scotland
My System: Technotrend 3200, Triax 80cm dish, Pace 2600C1, Thomson DSI 8210, Raven 60cm dish. Skyline DSR 6000, Stab motor. | He means offline downloading. You don't subscribe to any ISP. Instead, you use a dvb card and software to grab data that other people are downloading by satellite. | ||
| | #6 | |||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | Which software is used? Be careful, if it is warez, don't give any links. The only thing similar to what you describe is Casablanca. Not sure if it is still available. | |||
| | #7 | |||
My System: Technotrend 3200, Triax 80cm dish, Pace 2600C1, Thomson DSI 8210, Raven 60cm dish. Skyline DSR 6000, Stab motor. | 7E OpenSky 11262/H/27500 Be warned, you will be downloading gigabytes of porn images. Last edited by thedavid; 02-06-2008 at 03:34 PM | |||
| | #8 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | Thanks. ![]() Any on Hot Bird 13E? | ||
| | #9 | ||
My System: Technotrend 3200, Triax 80cm dish, Pace 2600C1, Thomson DSI 8210, Raven 60cm dish. Skyline DSR 6000, Stab motor. | Providers on 13E (Not sure if these as open or scrambled): Teleborsa 12539 H 27500 British Telecom 10723 H 27500 Bolsa 12092 H 27500 OpenMux 12578 H 27500 I forgot to mention that you can filter the data into videos, images, documents, archives, etc. And you can filter out data such as images if you don't want them. Also, you can make custom filters. | ||
| The Following User Says Thank You to thedavid For This Useful Post: | HB13DISH (02-06-2008) |
| | #10 | |||
![]() Will try with the Skygrabber 15 days evaluation. Should be interesting. | |||
| | #11 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | OK. Installed Skygrabber, card is recognized, tried all the providers in the list for Hot Bird 13E, but there are no files to download. Looks rather useless so far. Am I doing something wrong? or these providers on this satellite aren't popular enough? If I understand correctly, I am supposed to dl files that others downloaded using satellite internet. As I have ADSL and can dl files by going to websites that have them, then what is the added benefit to this method? | ||
| | #12 | |||
The benefit is that you can download files and nobody can find out that you have downloaded them. | |||
| | #13 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | Thanks for the info. ![]() Still no files are shown from ALL providers listed for HB 13E I even added few but nothing seems to help. Can you please check if you can see any files from any provider on Hot Bird 13E and which one? This way I will know if there is something wrong with my system. Any other Applications apart from those mentioned above? | ||
| | #14 | |||
You might want to try another software like Skynet. Skygrabber has some problems. For example, if you download a large file, it stops at 99% completed and then deletes the file after timeout. And it seems to not download videos unless also downloading images at the same time. Last edited by thedavid; 03-06-2008 at 08:54 PM | |||
