help!!!my altdvb can not capt all the frequency of channel | |
| Member Join Date: 02-06-2008 Location: NORTH AFRICA /TUN
My System: hi all |
i have a huge problem i have skystar 2 and it did not work whith altdvb(all version) the problem is tha it not capting all the frequency (it work with prog dvb and my theatere ) but i prefere altdvb because is the best i think but he did not work and i use cable direct from disc plzz any one have solution ![]() | ||
| Member Join Date: 04-01-2008 Location: India
My System: 6 Feet C band in Insat 2E 8 Feet C band in Asiasat 75 cm Ku in Insat 4B Kaon Receiver Pentium 4 1.7 GHz | Yes, I am also suferring from the same problem. I think this is because of old device file for SS2. I am using SS2 H/W version 2.8A. It can only tune Ku low band vertical signal only. And can't use Diseqc. But I can watch all the channels using DVBdream. But we need to select the SDK device file on the first time opening the software. If we use the direct driver option then we can only tune Ku low band channels only, like AltDVB. So the problem is must be in device file. I send a e-mail to the developer of Altdvb. He is in the process of new version of AltDVB. We can expect new device file for SS2. The exicisting ile is 2 year old. So we need new one for new H/W version. As per my knowledge, many people who have old version of SS2 can use AltDVB without anyproblem. I like AltDVB very much because it's faster than any other DVB player. So I am also waiting for new version of Altdvb and new device file for SS2. | ||
| The Following User Says Thank You to anishpsla For This Useful Post: | bokman (04-06-2008) |
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I've had similar problems using that SS2 hardware version with Linux running Kaffeine. No driver exists as far as I know. Luckily I still have an earlier SS2 card (v.2.6) Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | bokman (04-06-2008) |
