New Freesat HD PC advice needed | |
| Member Join Date: 07-12-2004
Hi, I am about to build a new Media PC for use with Freesat HD. I intend to use mediaportal as the tv viewing software and i only want to view the normal Freesat and Freesat HD channels. My current plans are to use an nvidia 8200 integrated motherboard and an AMD 4850e processor with a pair of hauppage DVB-s2 cards, will this system be powerful enough to display 720p hd? I do not currently have a dish installed what would you recommend? i live in the south of england and have a wall that faces directly south. is there any reason why i should not buy something like this? Ebay it appears to offer everything i need for under £50? Thanks for any advice you can offer | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Hi, Yes, the dish setup would be fine. You should be able to install it yourself too, if you have some DIY skills. ![]() Sorry, I haven't a clue about media PC setups. Robbo
__________________ | ||
