SS2 PRogDVB & Matrix CAM | |
| Regular Member Join Date: 21-06-2004 Location: Staffordshire
My System: Phoenix Apollo ci converted to OpenBox. Sky_star 2 PCI card. Nokia DBox2c. Sagem Dbox2c. 60cm Channel Master @ 28° ALPS LNB. 60cm Channel Master @ 19° Syntec 2000LNB. Diseq Switch. Panasonic TU-DSB30. Duolabs Dynamite & Cas2+ interface. Matri |
Hi all, Just got my self an old matrix cam (revolutions) and cas interface 2+ to play with off fleabay. Question is how do I get ProgDVB to see the cam, is it via the cas interface or do I need a pci to pcmcia adapter? I'm not that bothered about clearing much, its just for self education. I have in the past succesfully used my Sly card in ProgDVB & SS2 using NDSCam & Duolabs Dynamite in phoenix mode, so I figured I'd just need cam and cas interface to connect to ProgDVB but maybe I'm wrong! If I do need adapter from PCI to pcmcia is there a prefered one? Any help much appreciated. | ||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | I don't think that there is an adapter for SS2. Try to open channels with plugins instead of CAM. | ||
