Twinhan vs Floppy DTV?? | |
| Member Join Date: 24-07-2008 Location: Malta
My System: I currently have a Skystar DVB-S but am trying to find a new card. I also have a Hauppage DVB-T |
HI all I am plannig to buy a new DVB-S card because I am fed up with my Skystar 2 and the problem it gives me with my motor and since I have an NFORCE chipset and it seems that skystar have problems with this chipset. I am planning to either buy the Twinhan AD-SD4000 or else the Floppy DTV2. Before I buy one of these items I want to ask some questions and if someone can help me I would be really grateful. Which card supports fully diseqc and can move the dish without problems? Which card has the best performance? I would be really grateful if someone can help since I do not want to buy a new card and then find out that I will have problem when moving the motor. Regards | ||
| Member Join Date: 30-09-2005 Location: North West, UK
My System: N/A at the MO | I can't comment on the Twinhan card (im looking to try a Twinhan VP-1034) but I have the FloppyDTV card. Have'nt really tested it yet, but here are my reasons for buying/observations.... Can fit in a PCI or PCI-Express slot (although uses FireWire), handy in my (HCPC) case with limited card slots Has a built in CAM slot, again handy if you have limited PC card slots. I think the Twinhan model you mention uses a seperate daughterboard for a CAM Performance seemed good, used it with an NForce4 AMD-3200 PC and no problems. Worked well with my Viaccess CAM and Pay TV card (SD channels, did'nt test with HD). Software provided with card is well written and does'nt seem to slow Windows boot/start up My setup uses a DISEQ switch which allows the card to switch between two dishes pointed at Hotbird and Nilesat. No motors involved, and was able to pick both satellites. Hope that helps | ||
