ProgDVB, XP SP3, SS2 PCI, no go so far. | |
| Member Join Date: 29-07-2008 Location: USA
My System: ProgDVB SS2 |
Hi all, I'm trying to get ProgDVB to work on XP Pro SP3 with a SkyStar 2 TV PCI that I just bought new. ProgDVB is version 5.15.5 and I just downloaded the driver (version 4.4.3.0) for the SS2. When I check the hardware/device I see it was installed ok but when I try to use ProgDVB I keep getting "Progdvb Engine ! Device not starting! (Sky Star 2) OK" BTW - I have tried both of the drivers (one says BDA and it shows up in the Sound, video and games controllers and the other shows up in the network). I have checked both (uninstall one then install the other) and each time I get device working normal in the device manager but still the error above keeps showing up. Any ideas on how to sort this out? Anybody got ProDVB to work on XP SP3 with the SS2? Thanks, SB | ||
| Member Join Date: 29-11-2004 Location: Bristol
| I'm getting this as well, ever since installing SP3. The only solution I've found is to open Device Manager (right-click "My Computer, Hardware, Device Manager), disable the SS2 and then immediately re-enable (I use the non-BDA drivers, so my SS2 shows up as a network adaptor). It's a pain having to do it after every reboot, but it works for me. s | ||
| | #3 | |||
It looks like ProgDVB is just not going to run on this computer. Perhaps the best thing for me to do at this time is to try some other DVB programs and see if I can get anything to work. Maybe later I can come back to ProgDVB and try to get it to work. Later, SB | |||
| | #4 | |||
| ASBO Club Member - Persona non grata Join Date: 10-08-2008 Location: romania
My System: i have six antenna,one toroidal with 16 lnbs 3 satellite receivers |
| | #6 | ||
| Member Join Date: 09-10-2007 Location: Bahrain (Middle East)
My System: Triax 60cm offset dish / single Invacom 0.3 LNBF / DM500-S | Hey all, I just got my SkyStar USB 2 recently, running XP SP3, with the latest 4.4.3 driver installed. Can't get ProgDVB to work either, but not too worried as I'm using my setup for one-way satellite broadband. | ||
| | #7 | ||
| Member Join Date: 05-09-2008 Location: China
My System: 138E,146E TBS DVB-S2 8920 card TBS Q-Box Ⅱ XP/Vista/Linux Ubuntu | Hi, have you tried to start device in Progdvb device list. If Progdvb is not working, you can try DVBDream,it's much stable than Progdvb. | ||
| | #8 | |||
My System: ProgDVB SS2 | Update - got it working. Looks like it had something to do with a package within the DVBViewer T.E. program. What I did was remove ProgDVB and DVBViewer T.E. using the add and remove programs from the control panel then re-installed the full 4.4.3 package (including the DVBViewer T.E.) then re-installed ProgDVB. Now it is working fine with SP3. BTW - I do not use DVBViewer T.E. and found it installs a program called server4pc in the startup folder. Check your running programs (CTRL-ALT-DEL) I found that this program can be deleted from the startup folder without breaking ProgDVB. Just be sure not to remove the program using the control panel. Another words install the full DVBViewer T.E. package then delete the server4pc from the startup folder then forget about it. ProgDVB has been working great for me ever since. BTW - for some strange reason DVBDream did not work for me after making the changes above. Because I now have ProgDVB working I did not spend much time trying to sort out DVBDream. Hope this helps, SB | |||
