LNB settings for QPH-031?
Thread Tools Display Modes
Old 30-07-2008   #1
My System: ProgDVB SS2
Hi all, I'm a bit confused on the LNB settings. On the box is says LO 10.75/11.25GHz and with my Mercury II receiver I use a setting of 10750 and it works great and have it locked down on Hispasat 30W.
I'm trying to get ProgDVB to work and have it hooked up the the other L port on the LNB. The default settings for ProgDVB are for a universal LNB and list:
LOF 1 9750 MHz
Switch 11700 MHz
LOF 2 10600 MHz
My questions are do I simply change both the LOF 1 and 2 to 10750?
What is the Switch frequency for?
Thanks for any help in clearing this up for me, SB
stumblebum is offline   Reply With Quote
Old 30-07-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
AFAIK, with this LNB, as you are using one linear port, you only have the one LO frequency (no switch frequency needed as with a Universal LNB) so clicking the custom box in the menu you enter 10750 and leave the other LOF boxes blank.
Try it anyway and see.
__________________
Llew is offline   Reply With Quote
Old 30-07-2008   #3
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
Hello!
i have also imported this lnb from usa last year for 150$ now the price is a little bit lower,there is a very big plastic wheater protection slider on my lnb,in europe we dont have this part!
the freqancy range is not the same on linar port,on circular it is a little bit higher,and difrent from orginal freqency,circulat signals on 36 e here very weak at the moment i can only reveive normal kuband signals without any problems
Turok is offline   Reply With Quote
Old 31-07-2008   #4
LOF 1 9750 MHz
Switch 11700 MHz
LOF 2 10600 MHz
Update - looks like I need to give up on ProgDVB for now (SS2 driver issues that I have not been able to resolve).
Trying to get DVBViewer to work instead and used the LOF 1 of 10750 and the other two blank and I think I'm getting close to getting DVBViewer to work. I can get a good solid signal in the transponder status box but I have not been able to make any sense of the channels. I will try to find out more about running DVBViewer and try to make it work.
Got to run, SB
Old 31-07-2008   #5
Turok's Avatar
could it be posible that some circular/linar channels sending in usa invers?
if so maybe you cant change it in the dvb viewer?
Forum Jump
