What files do I need (vplug+softcam) | |
| Member Join Date: 30-08-2008 Location: UK
My System: SKY (FTA) Dual LNB - Hotbird/Astra SkyStar 2 PCI (with ProgDVB) Maybe AtlanticBird if I can find WWE feeds |
OK guys, Im all set to go with my Sat sytem/PC setup. I have all the files I need (I think) but am unsure which ones are needed and which are not. I have gotten hold of the latest softcam but there are a lot of files inside it, ie. V_*.db , TPS.bin , s2emu.* , SBCL.ini , AutoRoll.Key. I am almsot sure I only need the V_*.db files (as this is what vplug askes for after install) and the softcam.key file. Am I right ? Cheers Just testing Hotbird atm, 19.2 wont be till ~2 weeks | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Yes, just the vplug and latest key files (v_keys.db and softcam.key, available from various upload centres). Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | tw4t (04-09-2008) |
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Just install powerInstall Softcam updater, then you don't have to worry about getting keys etc. | ||
