vplug
Old 22-10-2008   #1
My System: FS4200, iss 70cm dish,single passion lnb and a compro s350 using dvbdream as the compro software is crap
vplug
is there a guide to using this prog anywhere
Ta Gaz
portly is offline   Reply With Quote
Old 23-10-2008   #2
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Not sure how transferable the knowledge is to your needs:
http://www.satellites.co.uk/satellit...50-post41.html
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is online now   Reply With Quote
Old 23-10-2008   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
For the basic vplug emulator without the SBCL plugin referred to by mhku, it just runs in the background of your DVB application; provided you have up-to-date keyfiles in the plugins folder, it'll work without any input from you.
Clicking on Show Monitor in the Plugin box of your running application gives you several tabs that allow you to update transponders and import keys. There's also an editor at the end that allows you to check and change parameters of channels, add and edit softcams etc.
Llew is online now   Reply With Quote
Old 24-10-2008   #4
Cheers chaps, i am thinking of using it with my pc card compro s350 and dvbdream, but its strange that a plugin is produced with no info on how to use it and seeing as im new to this sort of thing , its rather confusing
vplug
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
Content Relevant URLs by vBSEO 3.3.0
