how to add a satellite in progdvb
Old 07-11-2008   #1
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
hi all set skystar pci up in my computer and used 19east as setup for channels found ok,now i am using my technomate to turn my dish to another position (then turn off)and i am wanting to add another satellite to my progdvb list but how,i can change the 19east to something else but i cannot add another satellite thanks p.s. its for 4.2.2 fedds mainly
iwol is offline   Reply With Quote
Old 07-11-2008   #2
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card
He battled for 3 days against the Tux and won! Hurray!!
You can try this in ProgDVB setup
Diseq None
Change the position of the dish to Hot Bird 13E using TM and from the setup menu
Add LNB (you may need to delete the Astra 19E)
Choose Hot Bird 13E and scan
You will then see the Astra 19E and Hot Bird 13E channels list at the bottom and you can select which satellite as you move the dish with TM
Perhaps there is a better way, but I remember that when I tried to define Amos 4W and then Hot Bird 13E, the Amos channels list was still there, even though I changed the coaxial cable to HB.
Let us know if this works for you.
HB13DISH is offline   Reply With Quote
Old 07-11-2008   #3
thanks hb for quick reply,like you say theres probably a better way,but for what i need its more than enough for my need,once again cheers
Old 07-11-2008   #4
Did it work for you then?
BTW: I liked your idea to move the dish using the TM.
But isn't this possible with ProgDVB?
Old 08-11-2008   #5
yes it did,have set two receivers up to use same v box to position dish before but in this case for the amount i will use it,the technomate is easier and better
Old 13-11-2008   #6
My System: 1fitted 2motorised win xp and win 2000 linux suse
hi there
why not move the dish with progdvb it has a positioner in it.
ad the positioner to it and one of the swithes a two ports or 16ports .
if u click on a empty then ad positioner next empty click for adding a switch then click on a empty to ad the sat.
next click on the sat u adding to it and click the list button mark the aliasbox of the satellite u adding then yust beside the box u can change the sat position u may double click and move the mouse a wee bit to get the number box open to put a sat number in..
i run my motorished dish with progdvb from 57.E to 33.0.W if i click on a channel it will move to it yust to let you now how somone else has it done.
regards muilbroeder
muilbroeder is offline   Reply With Quote
Old 14-11-2008   #7
thank you will try
add, progdvb, satellite
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
Content Relevant URLs by vBSEO 3.3.0
